Go to Post You know you've overdosed on FIRST when you hear people yell "CHARGE" and you get confused and lost when you look and see baseball and not robots - thatphotochick [more]
Unread 05-02-2007, 09:59
HellBoy HellBoy is offline
FTC #2230
HellBoy is an unknown quantity at this point
Motor speed
If I want to programm the robot so that the viktor will turn as the same speed as the spike ,what value should be given to the pwm?
Unread 05-02-2007, 10:06
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Motor speed
the value you should give the pwm in programming is 255
Championship - Delphi "Driving Tomorrows Technology"
Unread 05-02-2007, 10:41
Re: Motor speed
The Spike relay is either on or off, supplying full power or no power to the load. There are two relays in each Spike, making it possible to power the load with either forward or reverse polarity.
To make a Victor speed controller supply full power forward, send it a pwm value of 254. To make it supply full power in reverse, send it a pwm value of 0. To make it supply no power, send it a pwm value of 127.
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
Multi-Speed motor Questions Burg Robotics Education and Curriculum 2 23-12-2004 15:54
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
Drill Motor Speed Difference Mark Jones Motors 2 14-02-2003 15:23
Drill motor true speed? archiver 2001 0 23-06-2002 23:58
