Go to Post You can either suck up a lot of oxygen, or you can contribute to our communal knowledge. The choice is yours. - dlavery [more]
Unread 05-02-2007, 01:09
Chuck_Norris Chuck_Norris is offline
AKA: Chuck Norris
FRC #1153 (RoboRebels)
Chuck_Norris is infamous around these partsChuck_Norris is infamous around these parts
Send a message via AIM to Chuck_Norris
DB15 pinout
hello,
I am in search of a pinout of the Joysticks that came in the kit of parts.
Any help would be greatly appreciated.
- Chuck
Unread 05-02-2007, 01:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: DB15 pinout
this thread
http://www.chiefdelphi.com/forums/sh...ad.php?t=52200
might help, it has a link to the IFI interface info for the OI module, which has pinouts for the four 15 pin ports.
Unread 05-02-2007, 10:39
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: DB15 pinout
Here is a photo of the joystick pinout if this helps,
Link to Joystick Photo
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 05-02-2007, 12:02
AKA: Chuck Norris
Re: DB15 pinout
That's exactly what I was looking for, thanks for the help!
-Chuck
Unread 05-02-2007, 12:48
Re: DB15 pinout
Andrew provided the pinout of the joystick port on the OI itself. Here's a link to a schematic of the actual white joystick: http://www.chiefdelphi.com/forums/at...achmentid=3098
Encoder Pinout bear24rw Electrical 4 04-12-2006 21:43
USB Joystick to DB15 team1307 Control System 7 21-01-2005 11:58
USB Joystick to DB15 team1307 Electrical 7 21-01-2005 11:58
usb to db15 663.keith Technical Discussion 21 20-01-2005 15:16
DB15, Male 15 pin connector. AdamT Technical Discussion 8 06-02-2002 17:17
