Go to Post "The lowly snowflake is very fragile, but look at what they can do when they stick together" - Wayne Doenges [more]
Unread 05-02-2007, 16:39
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Re: Code to have speed of motors dependent on how hard you push the joystick
Another simple check: the victor controllers pwm's are connected to the RC pwm 13,14,15 or 16. You can't connect them to PWM 1 thru 12 ... that's from memory ... if you do the victors will pick some speed and never change like you described.
Code to increase speed when joystick is pushed further JoJo5 Programming 3 06-02-2007 07:29
How Many Motors Have You Dropped This Year? littleelectron Motors 5 05-02-2004 16:03
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
How fast are you planning to push/pull a goal? Anton Abaya Rules/Strategy 7 12-01-2002 23:33
