Go to Post (pfft, kid... I sound like I'm Baker's age) - Amanda Morrison [more]
Unread 05-02-2007, 16:41
Cheezmeister Cheezmeister is offline
FRC #0871
Cheezmeister is an unknown quantity at this point
MPLAB/c18 not creating a .hex file
Basically, the topic. I believe it's a problem with the project settings, as it only happens with certain robots' codes. It will compile, create .cod & .coff files, mysteriously omit the .coff to .hex conversion, and declare the build complete.
What would this be caused by? I have no idea where to start, so info on settings will be provided on request. Thank you ^_^
creating hex file seanl Programming 4 03-02-2007 22:08
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
hex file garbage? sciguy125 Programming 2 04-07-2005 23:04
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
