Go to Post Smaller FRC bots...... This is what the Mayans were referring to.... My world is ending.... - CrazyHorse [more]
Unread 05-02-2007, 18:49
thrash16 thrash16 is offline
FRC #1726
thrash16 is an unknown quantity at this point
Exclamation Help: Changing Maps in Ink and Paint
Our team has just started animation this year and have only about a months experience with 3ds Max. In our animation we have an Ink and Paint bitmap that we need to fade to another Ink and Paint bitmap.
We would have an exact copy of our object (in the excat same place and rotation) with the material it fades to. The original object's material would fade to a 0 opacity so it appeared to fade to a new material. But with an Ink and Paint bitmap we cannot control the opacity of the map (as far as we know).
Any help would be great!
Unread 05-02-2007, 20:07
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
3dfernando will become famous soon enough3dfernando will become famous soon enough
Re: Help: Changing Maps in Ink and Paint
Did you try to mix two bitmaps and just change the mixing amount?
Instead of putting the bitmap file, put a "mix" map. Then fill the two former fields with your pictures and leave the third one with "none". Now, you can control the mix amount and the maps will blend.
I think this is the effect you want to make =)
But if i thought wrong, let me know =P
Good luck with it ^^
Unread 07-02-2007, 21:19
Popper99 Popper99 is offline
None #1726
Popper99 is an unknown quantity at this point
Thanks alot! Thrash and I are the only members (not to mention newbies) working together on the animation and I just wanted to let you know it works perfectly
Unread 08-02-2007, 17:32
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Good luck on your animation!
reflections/shadows in 3dsmax with ink and paint? Sam Ketner 3D Animation and Competition 7 18-01-2006 08:32
reflections/shadows in 3dsmax with ink and paint? Sam Ketner Inventor 0 16-01-2006 21:31
Ink n' Paint Texture Question Ryan Dognaux 3D Animation and Competition 5 13-01-2005 16:06
Maps for FLL and not just FRC? KathieK FIRST Lego League 5 22-11-2004 12:02
IRI maps, agenda, etc.. tminard Off-Season Events 10 11-07-2003 23:26
