Filemaker Help?
I'm working on a FileMaker database for scouting this year. However, I've never used FileMaker before.
What I'm trying to do is set up an entry field of different metrics that are entered match by match for a specific team.
For example, if you were scouting Team xyz for match 1
you'd enter xyz as the team #, 1 for the match # and fill in the various parameters.
So far I have the entry fields set up, but I was wondering how to set up the records so that I can do the following:
>>Use the same form to enter each match (over several computers)
>>View ALL the match data sorted into groups of team, then match #, so if you looked up team xyz, you'd see a list of matches they were in, what teams they were with/against, and what they did in each match
>>network this database (i don't need as much help with this one)
"In the race between the rock and the pig, do not varnish your clams."
