Go to Post It's kind of magical how I went from legos to replacing most of the iron in my blood with aluminum, and all thanks to my elementary school science teacher. - Astrokid248 [more]
Unread 29-01-2007, 16:09
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
CIM motor on 30A
we are using 4 2.5in CIM motors for our drive train and we are going to use a 3in CIM motor for our mechanism to lift other robots and i want to know if I have to put in one more maxi block to run the 3in or if I can just run it of a 30A fuse
Jason
Unread 29-01-2007, 16:13
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: CIM motor on 30A
motors should be run at the recommended level. no more, no less.
Unread 29-01-2007, 16:20
REVving up for a new season
FRC #2848 (All-sparks)
not nessicarily true. You can gear the motors to match their performance curves, and in some situations (low torque, High speed) it may be better to gear them to have a max torque at 30 amps. There are no rules against using smaller breakers, because the only side effect for a mistake is a tripped breaker. If I recall correctly in years past pre-2004 there were no 40 amp breakers, cims were run on 30's and didn't have a problem.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 05-02-2007, 20:10
Jared Russell's Avatar
Taking a year (mostly) off
Depends completely on the application. Last year we had our flywheel running on a 30A breaker during testing, and it never had a problem because it wasn't drawing much current at all.
Unread 05-02-2007, 20:23
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
depends on the load on the motor. unless it is a high-load situation or you want to switch directions quickly (full fwd -> full rev), the 30A should be fine. Test it, you can always replace it later if you have problems.
dewalt motor VS. CIM motor John Gutmann Motors 12 10-01-2007 18:57
Large CIM motor Wayne Doenges Motors 3 06-03-2006 21:24
CIM-MOTOR source Andrew Schuetze Motors 6 18-05-2005 11:57
CIM motor issue dmellich Motors 4 11-02-2005 11:10
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
