Miniature Joystick
Does anyone know where I can get miniature joysticks, like finger joysticks. I have only found one, and it was really expensive and had to call the company to get a pricing. If anyone could help, that would be great.
Re: Miniature Joystick
Yeah, you take the junky beige joysticks from the KOP, hack off the handles, and replace them with whatever you want.
That's the route I'd take; mod the KOP joysticks. JBot |
Well this isnt really the entire joystick, but it is very small and i would think all you need to do is build a case for it, but it is really small!!!
http://www.phidgets.com/index.php?module=pncommerce&func=itemview&KID=1170 71329564.252.38.112&IID=80 |
This might be too small!
Digikey: http://rocky.digikey.com/WebLib/CTS/...2A103B60NA.jpg http://www.digikey.com/scripts/DkSea...=60638&Site=US |
http://www.p3america.com/industrial_...tion_guide.htm
Has some good ones. They make great full size joysticks as well (one to three axis, up to three detents on each axis, and a variety on auxiliary input options on the sticks, too.) |
You could also hack the ones out of a playstation controller, they are nice and thumb sized, the design is just 2 spring loaded pots and a micro switch. With a good interface that could be a really nice system
#7
If all else fails, make your own. Someone else on the forum is already doing just that. Good luck in your search.
#8
thanks for all the replies guys. P3america was the website that I tried before and #1 there is no order link and #2 i called and they want me to sell them my soul for these joysticks.
#9
i dont have the information on hand right now, but i would check with suppliers of arcade equiptment. Also check with FRC228 members, Art Dutra [3 or 4] or Ben P, i know they made some last year.
#10
I was actually VERY satisfied with P3 America. I orderer 4 802 joysticks at $9 each. The shipping was $5 and I got them from CA to Miami, FL from Friday to Monday. It was all $41 called in the order for 4 pushbutton joysticks. I would tell you to try calling them again
#11
The ones from p3 look great, however, it appears they are all 10k ohm. Don't we need 100k ohm for the OI?
#12
No, according to Kevin W. anything above ~5k works well.
#13
Keo-San, Ill try again, maybe it was just the one switch I was looking at, I was checking out the rocker switch because we only need it for one axis use. Its low profile and it would of fit perfectly. If I do buy one of these, do you think I could contact you and you could help me wire them up?
#14
I'm quite sure he was refering to the RC inputs, not the OI. Although I have heard that teams have had success with pots that are not 100k, IFI explicitly reccommends them. |
| 1 joystick or 2? | ChrisMcK2186 | Control System | 18 | 19-01-2007 23:42 |
| Where to get miniature hydraulics? OR... | sanddrag | Pneumatics | 13 | 08-12-2005 10:54 |
| Joystick | cammie825 | Technical Discussion | 1 | 15-01-2003 10:48 |
| Miniature Innovation First RC System | BSMFIRST | Technical Discussion | 13 | 27-07-2001 02:24 |
| Miniature Robots | David Kelly | Technical Discussion | 4 | 31-05-2001 22:06 |
