Go to Post Sleep is for the weak in week 6! - JesseK [more]
Unread 05-02-2007, 20:32
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Best way to start
What is the best tutorial online for learning C if you have never done any programming before and need to learn fast at first
Unread 05-02-2007, 21:18
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Best way to start
I always recommend getting a book. It is the easiest to learn from, since you can read it even when you are not at the computer.
However, this is a good C tutorial: http://www.cs.cf.ac.uk/Dave/C/
Unread 05-02-2007, 21:31
If you want to program a FIRST Robotics Competition robot, you'll probably be best off using EasyC. It leads you through everything you need to know to get started.
Unread 05-02-2007, 23:16
If you are interested in a book, the classic book on C is "The C Programming Language" by Kernighan and Richie. My brother was reading it, and found it VERY informative and easy to understand.
Unread 06-02-2007, 12:27
shawger shawger is offline
Programming Subteam Leader
FRC #1732 (Hilltopper Robotics)
shawger will become famous soon enough
Another good one is Programming in C by Stephan Kochan.
But if this is your first year as a programmer, and you're just starting to learn C now (5th week!), you'd probably be best off with EasyC. It will let you get started fairly quickly, and you will be able to start working through programming concepts right away without dealing with all the syntax.
Best Way to Shoot the Balls?? ben281 Rules/Strategy 54 16-01-2006 09:57
best way to score in the lower goals ?? Dakota Snow Rules/Strategy 17 11-01-2006 18:12
Best way to download an entire website sanddrag IT / Communications 6 18-12-2005 00:59
Best way to make money! SPDEXL Fundraising 17 21-07-2003 01:19
What is the best way to learn? Tton 3D Animation and Competition 7 25-03-2003 19:22
