Re: Victor Braking Feature
The other options are to provide a mechanical brake or to use a gearing system that won't backdrive. |
I think the issue you are having is with motors backdriving. The window motors and the denso are the only motors I know of that do NOT backdrive. Other wise, you'll need constant current as described above.
Another option, although this is almost never possible on robots, is a counterweight Last edited by tdlrali : 05-02-2007 at 23:46. |
I almost made that generalization, but I wasn't 100% sure. Thanks!
You're on the right track, though; locking the mechanism with a worm gear is better than stalling your motor to hold it in place. |
| Victor Braking | patTeam241 | Electrical | 5 | 21-01-2005 14:00 |
| Victor 884's not behaving the same as Victor 883's | programmer1 | Programming | 13 | 10-03-2004 21:51 |
| Dynaminc Braking on Victors | Max Lobovsky | Control System | 7 | 06-02-2004 13:43 |
| Victor braking feature | MattB703 | Electrical | 12 | 21-06-2002 07:26 |
| Cool feature... | Joe Johnson | CD Forum Support | 4 | 01-06-2001 16:45 |
