Go to Post Its a good idea to learn to tame CAD monkeys. They're very useful. - Akash Rastogi [more]
  #34   Spotlight this post!
Unread 05-02-2007, 22:48
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: Banebot 56mm gearbox - double D - RELOADED
Originally Posted by Arkorobotics View Post
If I took out the CIM spacer cut it down to the right size to fit and cut down the CIM's shaft to be flush with the gear, and Lubricated it would this help prevent Binding and a risk of the plate breaking?
Probably not. This would help the gearbox and motor run smoother, but it will transmit torque as well or better than it did before, meaning the double-D could still deform over time.
Update on the tempered C40-hardness A2 tool steel carriers: We finally got around to re-mounting and testing today. The HS kids enjoyed the opportunity to do wheelies and driving it like crazy in a confined area. After about 5-10 minutes of driving, a sprocket bolt fell off (somebody forgot locktite) and everyone suddenly had to leave instead of fixing it.
I wouldn't call this definitively tested, but they didn't fracture and there is no backlash to be seen right now. More testing to come tomorrow.
Our drivetrain is 1 CIM, 12:1, going to a 6WD. See attached pic.
Edit: Yes, I know the shafts aren't well supported. O_o
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
