Go to Post Our strong support is the result of 14 years of very organized "nagging". :) - OZ_341 [more]
  #37   Spotlight this post!
Unread 05-02-2007, 23:44
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Banebot 56mm gearbox - double D - RELOADED
Originally Posted by ZZII 527 View Post
Yep, ours ran much more smoothly too after some tweaking. I was just saying that I think the alignment and spacing issues are separate from the double-D issues. Solving one won't fix the other.
An earlier estimate from Dr. Joe was that 350 in-lbf, in repeated, high-cylce loading was a safe estimate for the amount of torque the plate could see before a problem occurs.
40N*M? thats a lot for our drive system. Our drive systems stall torque is 38N*M.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
