Go to Post Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate. - Calvin Hartley [more]
Unread 05-02-2007, 21:28
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
New version of FIRSTclipse: 0.0.3
A new version of FIRSTclipse is available.
Project page
A default code project will go up. I'll post here when that happens.
Note: I do not have a "extract & go" version of this due to the fact that my host is down ATM.
Unread 05-02-2007, 22:44
AKA: Jamie Bliss
Re: New version of FIRSTclipse: 0.0.3
An archive of the project is online at http://firstclipse.sourceforge.net/d...irstclipse.zip (118K)
To import:
  1. Open Eclipse and install FIRSTclipse, if you haven't yet
  2. Go to File > Import
  3. Select General > Existing Projects into Workspace; hit Next
  4. Select "Select archive file", and browse to where you downloaded the archive above. Select it.
  5. Press Select All and hit Finish
There will now be a project called "default_2007". This is where the code is. I recomend renaming it, since it won't be the default code for long.
If the project doesn't build immediately, you will need to check Project > Auto build.
Eclipse is featureful. Be sure to just explore the menus, buttons, options, property dialogs, and whatnot to get a feel for it.
If you want to use any of Kevin's code, you should be able to just extract his files into the project folder, on top of the default code.
If you have any problems, contact me or post on here.
Unread 05-02-2007, 23:03
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Sounds good.
I'm using the older version and loving it, how would I go about updating to the newer?
http://www.mikesorrenti.com/
Unread 05-02-2007, 23:06
Link = Not working.
Unread 06-02-2007, 00:53
AKA: Jamie Bliss
Oops, I always forget that step. (Darned unix permissions!)
It should work now.
Unread 17-02-2007, 16:11
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
The "stable" release on source forge isn't working for me. It says it is only 612 bytes.
Unread 17-02-2007, 21:39
AKA: Jamie Bliss
Download it again, then. Both the toolchain and the error parser download fine for me.
Unread 18-02-2007, 19:56
ericand's Avatar
AKA: Eric Anderson
The jar file at http://firstclipse.sourceforge.net/update only downloads 612 bytes for me. I've tried this from several directions (using network connections through various routes and using IE and FireFox).
The archive of the project (http://firstclipse.sourceforge.net/d...irstclipse.zip ) worked just fine. I had downloaded the original project, but was having trouble configuring it so I wanted to try the stable release.
Thanks for your help.
Unread 18-02-2007, 21:06
AKA: Jamie Bliss
Ah.
http://firstclipse.sourceforge.net/u....fdt_0.0.3.jar is the feature only. It is not the plugins. http://firstclipse.sourceforge.net/update/ should be given to the Eclipse update manager as a new remote site.
New version of WPILib BradAMiller Programming 26 27-01-2007 15:49
Stamp is probably not releasing a new version this week. buss Scouting 1 29-03-2006 22:10
pic: Version 1.2 Arefin Bari Extra Discussion 12 02-12-2004 21:53
Under Control Website! New Flash Version! physicist Website Design/Showcase 11 22-02-2003 02:41
Stack Attack PDA Scoring Calculator - New Version Matt Starkey Rules/Strategy 1 16-01-2003 22:27
