#14
Re: Code to have speed of motors dependent on how hard you push the joystick
Quite right the victors don't really care what PWM you use. I was working from memory (don't do that .. read the manuals first before posting :-)
However the original FRC code only drives 13-16 without you doing extra coding. You might also want to look over here: http://www.chiefdelphi.com/forums/sh...ad.php?t=53527 another possible problem. |
| Code to increase speed when joystick is pushed further | JoJo5 | Programming | 3 | 06-02-2007 07:29 |
| How Many Motors Have You Dropped This Year? | littleelectron | Motors | 5 | 05-02-2004 16:03 |
| How do you connect the speed controller fans? | Iain | Electrical | 7 | 31-01-2003 07:05 |
| How do you set a speed limit on the servo | Fares | Programming | 6 | 01-01-2003 15:04 |
| How fast are you planning to push/pull a goal? | Anton Abaya | Rules/Strategy | 7 | 12-01-2002 23:33 |
