Go to Post I learned... that I need to learn more. - Erin Rapacki [more]
Unread 04-02-2007, 17:57
JoJo5 JoJo5 is offline
JoJo5 is an unknown quantity at this point
Code to increase speed when joystick is pushed further
Right now, I just have tank drive-2 motors, 2wheel drive setup, with two joysticks. No matter how far the joystick is pushed forward or backward, the motors turn the same speed. How can I set it up so that when pushed a little, the motor goes a slower speed, than pushing the joystick full throttle?
Unread 04-02-2007, 22:46
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Code to increase speed when joystick is pushed further
They aren't always going the same speed watch the LEDs on the victors full forward is green and full rev is red and anything in between is off. If you are just touching the joysticks and its going full speed something is wrong.
Unread 05-02-2007, 15:05
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Some things to look at. (If I am starting too simple, bear with me because some people reading this may need the info.) Did you initalize the motors in the "Initialize" portion of the program? This sets the correct PWM port to the motors. Second, did you put the "2 motor tank control" in the operator's portion? Did you set the variables in the tank control? Most inputs are self explanatory. If you have done this, you are past my knowledge.
Unread 06-02-2007, 07:29
AKA: Brad
#0190 ( Gompei and the Herd)
Can you make sure that you are calling the Tank Drive block inside of a loop? That block takes the current joystick values and sends them to the motors. Often people only use the block once - but there should be an infinite loop in the OperatorControl function that contains those blocks so they are called repeatedly. If the block is only used once, it will only send once speed to the motors.
Brad Miller
Robotics Resource Center
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
Gradual Speed Increase Booger Programming 2 24-07-2006 15:44
Joystick Wheel Code Vashts6583 Programming 1 30-01-2006 20:22
Gradual increase in speed? Kevin Rugani Programming 1 27-03-2003 21:36
One Joystick Code fs_2002 Technical Discussion 3 16-01-2002 00:47
