Re: Victor 884 calibration
In this case, the first thing I would do is calibrate the Chicklet. Follow the directions in the manual here. If you calibrate your robot code or Victors to match whatever the joystick is outputting now you could create a dangerous situation. Consider this: if your Chicklet is outputting a value of 110 when the joystick is centered, and you calibrate to this, then if the Chicklet gets unplugged (setting the joystick value to 127), your robot will drive forward. As a rule of thumb, you always want to start by calibrating your joystick such that it outputs 127 when it is centered.
| Victor Calibration | railerobotics | Electrical | 11 | 16-01-2006 18:24 |
| Victor 884 Calibration Incorrect | Just3D | Electrical | 4 | 15-02-2004 15:20 |
| Recalibrating Victor 884 | Greg | Electrical | 8 | 18-02-2003 14:07 |
| Victor 884 | Kevin Ray | General Forum | 25 | 28-01-2003 15:02 |
| Victor 884 | Gary Bonner | Technical Discussion | 4 | 14-01-2002 08:10 |
