Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 06-02-2007, 09:16
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: do we "NEED" the power distribution block
William and Mike,
I don't think that the Q&A fully addressed the cutting of the jumper plugs. If that is allowed in the future, it must include a note to fully insulate the cut end. Quite frankly, the majority of weight is already there, and having an extra block to add functionality later would be a desirable thing. If you are using a four motor drive and 40 amp breakers, you need at least two red and three black blocks anyway.
The instructions on assembly for the module specifically state that it can be cut: http://www2.usfirst.org/2007comp_173...Strip%20R3.pdf
15) The assembly may be shortened as desired by removing the extra terminals and cutting the DIN rail and the center jumper bar(s) to the desired length(s).
In addition, a 4 motor drive with 40A breakers, and only one 20/30A fuse block could be satisfied with 2 red and 2 black, as the same document states that you can put 2 10ga or 3 12ga wires in the same connection:
Maximum Wire Size and Max Quantity Allowed per 1492-J16xx Terminal
1 - #6 or
1 - #8 or
2 - #10 or
3 - #12 or
4 - #14 or
4 - #16
(2 connections for 4 12ga wires and 2 connections for 2 6ga wires on the black, 3 connections for 3 6ga wires on the red).
Given that these are the instructions they are providing us on how to assemble this, unless there is a rule that specifically makes this illegal (which I was unable to find), as far as I am concerned it should be legal.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Power Distribution Block Grounding Karma Electrical 15 22-01-2008 07:18
Question:Power Distribution Block Pavan Dave Electrical 35 20-03-2007 20:10
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
