Go to Post Hey people, I found out the answer to my question and that one guy eric is right all you have to do is read the manual. The rules are in chapter 7.3.5.1, sections - .:) - ronald [more]
Unread 06-02-2007, 08:59
Re: do we "NEED" the power distribution block
Originally Posted by MikeDubreuil View Post
You know what they say about assuming...
You and me...both!
Unread 06-02-2007, 09:16
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
William and Mike,
I don't think that the Q&A fully addressed the cutting of the jumper plugs. If that is allowed in the future, it must include a note to fully insulate the cut end. Quite frankly, the majority of weight is already there, and having an extra block to add functionality later would be a desirable thing. If you are using a four motor drive and 40 amp breakers, you need at least two red and three black blocks anyway.
The instructions on assembly for the module specifically state that it can be cut: http://www2.usfirst.org/2007comp_173...Strip%20R3.pdf
15) The assembly may be shortened as desired by removing the extra terminals and cutting the DIN rail and the center jumper bar(s) to the desired length(s).
In addition, a 4 motor drive with 40A breakers, and only one 20/30A fuse block could be satisfied with 2 red and 2 black, as the same document states that you can put 2 10ga or 3 12ga wires in the same connection:
Maximum Wire Size and Max Quantity Allowed per 1492-J16xx Terminal
1 - #6 or
1 - #8 or
2 - #10 or
3 - #12 or
4 - #14 or
4 - #16
(2 connections for 4 12ga wires and 2 connections for 2 6ga wires on the black, 3 connections for 3 6ga wires on the red).
Given that these are the instructions they are providing us on how to assemble this, unless there is a rule that specifically makes this illegal (which I was unable to find), as far as I am concerned it should be legal.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 06-02-2007, 09:21
Brian,
I agree that the instructions from Rockwell say it can be cut. But the normal use of this system is inside an enclosure where there will be no contact with other parts, electrical and mechanical. Our use has not been fully considered for insulating the cut ends and I am hoping that the GDC addresses this in the future.
Unread 06-02-2007, 09:28
FRC #0190
Brian,
The instructions don't seem to be generic, however, as the drawing has FIRST in the part number, and the written instructions specifically reference that drawing.
Unread 06-02-2007, 09:31
Note that the drawing and instruction sheet in your link all have "Rockwell" on them. I believe that the drawing was made for FIRST but that the instruction sheet is the one provided to installers by Rockwell.
Unread 06-02-2007, 10:08
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
are the ground wires from the speed controllers that go to the 4 cims required to be connected to the block. currently i have them connected through the breakers.
Unread 06-02-2007, 10:23
Yes, that is the recommended method. See the latest revision of the electrical drawing and the Tips & Guidelines. It also minimizes the voltage losses to the RC due to the high currents of the motors passing through the smaller fuse panel. I know this is hard to visualize but the current provided to a motor (speed controller power in) and the current returning from the motor is the same. Since a Chalupa motor stalls at a over 100 amps, that current is flowing through both the red and black wire. For every foot of #10 (black or red)that equates to a 0.1 volt drop.
Unread 06-02-2007, 10:30
seanl's Avatar
i know that it is what is recommeded but would we pass inspection if its connected through the breaker.
Unread 06-02-2007, 10:36
Sean,
I would say that this is a question for the Q&A to be sure. However, in my opinion, I would say no, under this part of the robot rules...
<R57> The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit breaker distribution panels must be connected as shown in the 2007 Power Distribution Diagram.
Sorry.
Unread 06-02-2007, 12:54
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
can you use more than the amount of blocks given to us (we happen to have a lot lying around) it would be nice to have easy access for everything
Unread 06-02-2007, 13:53
I am not sure you need them or would want to run different paths for your positive and negative wiring. You are talking about the Rockwell blocks? If you are using the small black panels, I believe there is no limit.
Unread 06-02-2007, 19:18
FRC #1360
well we might not have them hooked up right then, I will have to look, but as it is.. we have our motors connecting through them to the victors and all the grounds of the victors go through different ones to form one wire and go to the ground terminal on the fuse block ( I'm sorry if it is confusing I'm not the electrical guy lol) so if there is a way in which we have to use these please tell so I can get them to rearrange now.
Edit: I just read was posted above me and I shall look at this power distribution diagram.
Unread 07-02-2007, 08:10
T,
Let me know if you need more help with this. If you PM me I can give you my email if that would help.
Unread 01-12-2007, 02:31
BlackShadowFox's Avatar
BlackShadowFox BlackShadowFox is offline
AKA: Madwolvez
FRC #0401
Team Role: Electrical
BlackShadowFox has a spectacular aura aboutBlackShadowFox has a spectacular aura about
Send a message via AIM to BlackShadowFox
Well I know this is kind of late in the game for the last year but I have a good feeling that they are going to bring the power distribution block back. Reason could be due to a contract or donation reason but that is just my guess and shouldn't be taken into to consideration because the true point is that it is required in the rules but however there is a few scenarios that have me confused on why you need the power distribution block.
Some information on wiring:
With the current battery cables at the gauge that they are it would be pointless to go a high gauge or doubling up on the same battery gauge in the controller system because your can’t exceed the power limitation set by that battery cable. The higher the gauge the more power can flow.
The longer the cable the more energy is lost due to resistance. So for example when Tomas Edison wired up a town with dc the power could only go a limited range because of the resistance.
Some of you said that the power Distribution block is a standard there I agree but grounding pins and other power products in that nature are also standards.
Questions and scenarios:
So if I were to make a robot with Only one ATC fuse panel ( 20/30 a ) would I need to use the power distribution block? Its required in the rules and also on the check list but it would serve no purpose.
(Because as far as I see I have only one grounding pad and one positive pad creating no reason for a Distribution block)
Ok let say I’m using two to three and maybe four fuse panels, using the fact from above about the battery’s wire gauge and also that the maxi fuse block is essentially a distribution block why would I need another distribution block when there are ones in place already? You may say resistance and you may have a point but I could say the same thing about the new distribution block.
I don’t know how many of you have looked at the inside of the New distribution block and understand how it works, but if you look there is a lot of wasted space. If you notice that in the base there are 3 squares, now if I was to drill a hole through all these squares I could run the battery cable through them that FIRST supplies. I also could do some other added things but as things go all will say I’m not allowed to tamper with these devices since I could make it unsafe not like I have shocked myself with an outlet 4 times or more to learn my lesson.
Now let’s say I have a maxi fuse block and an ATC fuse panel. Could I ground the four 40 AMP speed controllers to that ATC fuse panel and not have to use the negative half of the distribution block?
Final Note
I would go into mounting but that is another story for when this year is revealed. Also I would like to note that though I don’t like the distribution block for the robot purposes I do enjoy it for my other projects such as my other post called the cart files where it would help with later modifications.
Well I know there is probably more cases others can think of that I’m missing but it is 2:30 am and I’m tired so I leave it for you to debate on and create your own opinions because who am i but a student that doesn't have a degree in electrical like some of you.
Curiosity killed the cat, satisfaction brought it back.
Unread 01-12-2007, 02:38
Gboehm Gboehm is offline
FRC #1516 (Grizzlies)
Gboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to behold
I didn't mind the block. I don't know why people are so upset, its required so complaining about it wasn't gonna change. The wires came loose, it was nature of the beast. The 2005 set up was nice, but we don't have it. Oh well.
2005 SVR Highest Rookie Seed
2005 SVR Rookie All Star
2006 WRRF Cal Games Winner
2007 SVR Winner
2007 #7 Alliance Captains Archimedes Divison
"Any sufficiently advanced technology is indistinguishable from Magic." - Arthur C. Clarke
Power Distribution Block Grounding Karma Electrical 15 22-01-2008 07:18
Question:Power Distribution Block Pavan Dave Electrical 35 20-03-2007 20:10
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
