Go to Post I would much rather educate the audience than dumb-down the game. - dlavery [more]
Unread 05-02-2007, 23:42
burkechrs1 burkechrs1 is offline
AKA: Chris
FRC #0668 (The Apes of Wrath)
Team Role: Driver
burkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to all
Send a message via AIM to burkechrs1
pic: Team 668 Robot Stowed
Unread 06-02-2007, 07:24
roberto1632's Avatar
roberto1632 roberto1632 is offline
FRC #1902
roberto1632 is an unknown quantity at this point
Re: pic: Team 668 Robot Stowed
sweet gripper
Unread 06-02-2007, 13:59
pstrapp's Avatar
pstrapp pstrapp is offline
FRC #2016 (MuMuPsi)
pstrapp will become famous soon enoughpstrapp will become famous soon enough
Where did you get the Blue treads? I'm guessing its the blue griptop stuff but I can't seem to find a distributor.
Unread 06-02-2007, 14:03
AKA: Chris
Team Role: Driver
i'll try to find the part number and distributor for you if you want it. it's nothing special/different from the other tread that you can buy from anywhere else though...
Unread 06-02-2007, 14:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It's the blue nitrile roughtop incline conveyor belting from McMaster Carr.
Is that a rotating "wrist" joint on the end of the arm? I like that. Although, that arm could be a lot lighter if you went to 1x1x1/16" box. There's 1 or 1.5 of your 4 lbs you need to lose.
Unread 06-02-2007, 17:51
AKA: Chris
Team Role: Driver
Yea it can rotate 90 degrees in one direction which is really all you need. It helps for the human loading part and driving around with the tube on...
pic: Team 668 Robot Ramp 3 burkechrs1 Extra Discussion 6 06-02-2007 21:29
pic: Team 668 Wiring Board burkechrs1 Extra Discussion 4 06-02-2007 01:56
pic: Team 668 Robot Ramp 1 burkechrs1 Extra Discussion 0 05-02-2007 23:40
pic: team 668 teaser#3 burkechrs1 Extra Discussion 3 30-01-2007 16:56
pic: team 668 arm teaser2 burkechrs1 Extra Discussion 1 29-01-2007 19:12
