Re: Purpose of .COD file
The only reason to generate the COD file (for our purposes) is because it also generates the list file. If you have no reason to look at the list file, you don't have to generate the COD file and can get around the 62 character path limitation.
| "Error.MCP" file after HEX file trans | iwdu15 | Programming | 1 | 24-01-2007 20:05 |
| Help! making an inventor file into an autodesk file | kjhobin | Inventor | 5 | 19-03-2006 23:04 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
| QotW 10-19-03: Purpose lost. | Madison | Rumor Mill | 4 | 22-10-2003 13:32 |
| Delta_t's purpose | Morgoth | Programming | 8 | 18-03-2003 19:26 |
