Go to Post No matter their age, no matter their generation, every mentor and student must be responsible for their actions, and for understand that compromise and maturity are the paths to team success. - Eugenia Gabrielov [more]
Unread 06-02-2007, 14:07
Jared Russell's Avatar
Taking a year (mostly) off
More than 6 RC digital input interrupts?
I'm trying to get all of our systems up and running, and it would make my life a lot easier if there were a way to get 8 interrupt lines running. Every bit of FRC code I've seen has a maximum of 6 (on rc_dig_in01 to rc_dig_in06).
Is there a way to get more without having to multiplex the interrupt lines externally?
Unread 06-02-2007, 15:40
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
Re: More than 6 RC digital input interrupts?
There are only 6 external digital interrupts on the RC. One way to add more is to have a second controller(I have used a VEX controller) with encoders or other devices using interrupts plugged in sending signals back to the RC through an analog output(PWM). However, this design requires the use of an interrupt port on the RC and some fancy code work. I used 1 PWM on the VEX controller linked to 1 interrupt on the RC to send a number 0-255 to the RC with reasonable accuracy then had the RC recognize the number as a command(100 means drive forward for example). This also allowed me to do calculations on the VEX controller and ease the load on the RC.
2010 Newton Division & Championship Winner w/ 67 & 294
2009 CMP Champion - Newton Division
2008 CMP Champion - Archimedes Division
2007 Newton Division & Championship Winner
Unread 06-02-2007, 15:41
Digital input pins 3-6 are already "multiplexed" into a single interrupt. You will indeed have to combine signals externally to make them all cause one of the hardware interrupts to occur, but extending the part of the software that checks to see which pin actually caused the interrupt is straightforward.
Analog vs Digital Interrupts and Processor Overhead brianafischer Programming 2 21-01-2007 08:50
Auton digital input ten3brousone Programming 7 20-03-2005 22:23
counting digital input CharlieWilken Programming 9 22-03-2004 19:56
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
