Go to Post We have donut eating contests to see who has the best legs. We paint our pigs. We argue about which time zone we are in. About 400,000 of us gather together to watch cars go around in a circle. We also build robots.Yep, our cultural norm is a bit different. - Andy Baker [more]
Unread 06-02-2007, 16:12
Shadow31's Avatar
Shadow31 Shadow31 is offline
The Line Between Insanity & Despair
AKA: ???
FRC #1405 (Falcons Robotics)
Shadow31 is an unknown quantity at this point
Send a message via AIM to Shadow31
Weird camera problem
I am sorry if this problem has been mentioned, but I haven't been able to find it in searches. This is our first year using a camera, and though we've made a lot of progress, we have one very frustrating problem that won't go away. When the camera is searching and gets to the right tilt, it skips panning there and continues to the next level. This seems to be only happening with the bottom search level. It otherwise locks on correctly, and isn't looking away from the light; I have tried the solution mentioned if it looks away from the light, and that makes it look away, so I know it's not the problem. Could anyone help me???
Killer Coding Ninja Monkeys do exist!
Unread 06-02-2007, 23:09
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Weird camera problem
Are you using EasyC?
We're not and were having a similar problem, so we tried kevin watson's code from last year and its been working better.
Edit: Has anyone else experienced/fixed this or have any idea what the problem might be?
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 07-02-2007, 14:07
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We had a similar problem. We had a high degree of out lights in the area and the camera occasionally saw one partially. For whatever reason ( I didn't dig into the code) this resulted in the camera restarting the search pattern.
Do this. Go into Kevin's code and disable the "new_search = 1" line and see if that fixes your issue. It fixed ours.
Unread 07-02-2007, 14:14
Shadow31's Avatar
AKA: ???
We are not using Easy C. The camera is mostly working fine, it's just the lowest search level. I'm starting to wonder if it will make a difference, since the light is 9 feet in the air, not directly in front of the robot (not to mention our camera will most likely be a couple feet above the ground) but we would still like to fix this problem. It still locks on correctly (though we're trying it on last year's robot and the robot is so beaten up, it won't drive straight towards it, haha). I'll try commenting out that line ASAP, though your problem sounds a bit different (it's not picking up any other lights, as far as we can tell). Hey, a little trial and error never hurt anyone... except when someone on our team decided to play chicken with the robot and hold the light directly in front of it, nearly getting run over.
Unread 08-02-2007, 18:46
Shadow31's Avatar
AKA: ???
Thank you so much Tom Line, it worked and now our camera is working great!
Camera Problem ta1234 Programming 1 29-01-2007 09:38
very weird camera movement! graphite Programming 3 14-05-2006 05:23
Weird problem.. devicenull Programming 2 13-03-2005 12:07
Weird problem with if statements psquared Programming 7 27-01-2005 13:02
camera problem miscar Programming 2 23-01-2005 12:06
