Go to Post Competing at multiple regionals or Championship events has no bearing on the life lessons you will learn or the unbelievable memories you will have--for that is what FIRST is truly all about. - Alivia [more]
Unread 06-02-2007, 16:52
Team 849 Team 849 is offline
FRC #0849
Team 849 is an unknown quantity at this point
Need help with joystick.
For our arm this year, we intend to use one joystick and on our joystick we have many thumb buttons as well as a wheel. What we need help with is how to program multiple buttons on a joystick on easyC, as well as set PWMs according to which button was pressed...
Any help would be much appreciated. Thank you!
Unread 06-02-2007, 17:31
Syncopation's Avatar
Syncopation Syncopation is offline
I can't make a dongle outta 25-pin!
FRC #0932 (Memorial Circuit Chargers)
Syncopation has a spectacular aura aboutSyncopation has a spectacular aura aboutSyncopation has a spectacular aura about
Send a message via ICQ to Syncopation Send a message via AIM to Syncopation Send a message via MSN to Syncopation Send a message via Yahoo to Syncopation
Re: Need help with joystick.
I typically use OI to Relay and OI to PWMs for buttons. (under RC Control on the Function Block tab in the sidebar)
Most of the instructions in the blocks are self-explanitory, but you just specify the controller port (on the OI), the button for relays (use printf statements to find what buttons correspond to which number if you aren't using the white controller FIRST gives) or the axis for PWMs, the PWM/relay number (on the RC board), and the direction (forward or back for PWMs, for relays, they correspond to on/off - 1/0).
Hope that helps!
Team 932:
2008 Oklahoma City Xerox Creativity Award
2008 Oklahoma City Autodesk Visualization Award
2008 St. Louis Chairman's Award winner
Home of the 2008 St. Louis Woodie Flowers mentor
2007 Kansas City Engineering Inspiration winner
2006 Lone Star Regional Finalist alliance member
A mathmatician, a physicist, and an engineer were all given a red rubber ball and told to find the volume.
The mathmatician carefully measured the diameter and evaluated a triple integral.
The physicist filled a beaker with water, put the ball in the water, and measured the total displacement.
The engineer looked up the model and serial numbers in his red-rubber-ball table.
Help with joystick lightning_blast Programming 2 12-02-2006 22:25
Help with Joystick connections ace123 Control System 4 19-02-2005 13:25
need help w/ joystick code willie837 Programming 6 02-02-2005 23:17
We need help with joystick control Team ICE #1611 Control System 4 24-01-2005 15:57
Help with code single joystick JamesBrown Programming 9 19-01-2005 00:42
