Go to Post you must understand when wearing that FIRST Volunteer shirt, you personally & directly represent FIRST, and you do the best job for FIRST as an organization, that you can in performing that job....Period. - cglrcng [more]
Unread 06-02-2007, 18:10
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Bad Radio???
I was testing our robot for the first time with all the components from this year(RC, OI, Radios, ect.). It worked fine, but every few minutes the robot would stop moving just like it was being disabled.
After the first time I checked all the cables, RC-Radio, OI-Radio, and the dongle but it did it again.
After the second time I stayed where I could see both the RC and OI indicator lights. When the robot would be disabled the radio modem light would flash between red, yellow, and green, very quickly in what appeared to be a random pattern. The lights on the RC radio all blinked quickly in a random pattern. It did this for 3-4 seconds then re-connected and worked fine.
I switched the new radios with one that were laying around from before 2005. We ran the robot for about another 10-15 minutes without any issues.
I did not change the cables, RC, or OI. When I switched back to the new radios it continued to loose connection.
Is this a radio issue? Has anyone else had this happen? Should I check anything else?
Eric Haskins KC9JVH
Unread 06-02-2007, 18:13
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: Bad Radio???
You will find significant discussion about this here:
http://www.chiefdelphi.com/forums/sh...ight=OI+Issues
Ricky Quinones
Director of Sales - VEX Robotics
Unread 06-02-2007, 18:35
AKA: Eric Haskins
Re: Bad Radio???
Thanks, I don't know hoe I didn't find that.
Eric Haskins KC9JVH
Unread 06-02-2007, 19:59
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Bad Radio???
I've been running both 1889's and 179's robot arroundd today and neither's radio's will work for more than 10 seconds without cutting out
Unread 06-02-2007, 20:09
yee haw!
Re: Bad Radio???
Lets keep all discussion on the issues in the above referenced thread:
Thanks
Ricky Quinones
Radio Transmiters PhusionReactor General Forum 8 03-08-2005 08:06
radio problem Anton Control System 1 19-02-2005 12:22
Radio Reception? KVermilion Control System 6 31-01-2005 07:45
How "bad" are motors with "bad" stickers? cooknl Kit & Additional Hardware 20 12-01-2005 10:33
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
