Go to Post If the GDC doesn't want better teams to strap components on to other robots, they should design a game that doesn't require better teams to strap components on to other robots to win. - Tom Bottiglieri [more]
Unread 06-02-2007, 16:06
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Can Victors work as ESCs without all of the other electronic components?
Hi, i was wondering if a victor can be used as a speed controller without all the other mumbo jumbo electronics.
Thanks,
Vova
Unread 06-02-2007, 16:07
AdamHeard's Avatar
Lead Mentor
Re: Can Victors work as ESCs without all of the other electronic components?
Yes. The victor only cares about the pwm signal, it doesn't matter where it comes from. I've used Victors with vex controllers and RC car radios before.
Unread 06-02-2007, 18:16
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
just looking to put one on our FIRST mobile
Thanks!!!!
Unread 06-02-2007, 21:54
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Ok, now question #2, how do I control the victor without wireless. I'm thinking an electric scooter throttle control but have no clue how to make that.
Unread 06-02-2007, 21:59
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
To control a Victor, you'll need a circuit that can produce a pulse width of 1-2ms at a frequency of no more than 120Hz. I'm sure that this suggestion will make me unpopular with some EEs around here, but a simple 555 circuit will probably get the job done for you. Then you can use a potentiometer to vary the pulse width, and the whole thing shouldn't even cost you $10.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 06-02-2007, 22:09
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Yeah, a 555 chip should get the job done. I recently stocked up on parts, and the 555 chips are down to about $1.69. Just check out RadioShack.
http://www.radioshack.com/family/ind...032058.2032230
Unread 07-02-2007, 17:31
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Is it as easy as buying one of those circuits, attacing a pot to it, on the other end the pwm and to the victor?
Unread 07-02-2007, 17:42
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
i don't think that would be to safe, if the duty cycle(i think that is what it is called) is below 50%, the motor will go backwards. you might want to use a small microcontroller for it, i would recommend an arduino, which is based off an ATmega8
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
I'm not entirely sure. This isn't how I'd do it; I'd put a robot controller and operator interface on there. That way, you can do a cool drive system like you would on the actual robot, and it would look way cooler. You don't need any radio communications at all; grab a tether cable, tether the two together, and fire away.
On a side note, please put a cutoff switch somewhere between the battery and motors that's easily accessible. A rampant "FIRSTmobile" could be a very scary thing...
JBot
Aren't signatures a bit outdated?
Unread 07-02-2007, 17:56
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
RobotLogic sells something called the IMX-1, which acts as a PWM signal booster, which runs inline with a PWM cable to operate Victors with standard RC equipment. It also mixes signals for one-stick driving, and uses a spare RC channel for inverted controls, which is useful in combat robotics if you get flipped over (assuming your robot can drive inverted), or to make backwards driving easier.
http://www.robotlogic.com/product_imx1.html
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 07-02-2007, 19:04
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Do a google search on 'servo tester'. It is a relatively simple circuit.
Also certain PIC type processors have PWM on board circuitry. Try a search also on PIC PWM.
Unread 09-02-2007, 01:22
Andy A. Andy A. is offline
Getting old
FRC #0095
If you choose to use a supplementry circuit to generate the PWM signal, be sure to familiarize your self with the calibration routine. It is likely that a custom circuit will not output values that match those the Victor expects from the IFI equipment. Calibration will force the victor to scale the values, allowing you to set neutral, reverse and forward to values the circuit can produce.
This also goes for anyone using a Victor with hobby R/C gear. The factory calibration makes the assumption of using a PC joystick and an IFI control system. With out those, the factory calibration isn't even close.
-Local
Unread 09-02-2007, 01:25
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Are you sure about that? If you actually read the Victor 884 data sheet, it definitely sounds like you're supposed to send a 1-2ms pulse with a frequency no greater than 120Hz. A 2ms pulse should be full forward, even though that's substantially less than 50% duty.
It's not quite that easy. You'll need a couple of capacitors and resistors, I'm sure. Search around for 555 circuits, or pick up a copy of Forest Mims' timers and op-amps notebook.
_
Unread 09-02-2007, 07:58
You can find a wealth of info on the IFI FAQ for the Victors here...
http://www.ifirobotics.com/forum/vie...4742c7 8d25be
From that page...
Here are the required input control signal characteristics of the PWM input signal for the Victor and the PWM Outputs for our RC units:
Period for the Mini RC PWM Output: 17.0 ms.
Period for the FRC Robot Controller PWM Output: 26.2 ms.
Maximun Rate: 120 Hz.
Pulse width: 1 - 2 ms
As the positive pulse width varies from about 1 ms to 2 ms, the Victor will range from Full Reverse to Full Forward. The Victor should be in Neutral at about a 1.5 ms pulse width.
Unread 11-02-2007, 02:02
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
JBot
Or....You can just have the robot controller on it if your going to go there route. I think all you need to do is set the team # to 0 or something like that. I have used the RC alone before, I just don't remember how I did it. I would say your better of spending 10$ on perfboard and a small microprocessor then just have somebody write code for you.
If you give more info on the project it would be easier to help. For example I can tell you to make an Hbridge, but I don't know if that would fit the project.
Or you can go to somewhere like pololu.com and buy there servo controller and buy a basic stamp and just use the serout command to send serial data to it. If you have the money for that i would say that would work just fine.
How Can I aim at the Vision Target Faster but without overshooting? NextPerception Programming 21 20-02-2007 11:26
Can we use old Victors KMAC42 Electrical 5 26-01-2007 12:37
Vex Components For Other Robots Robots_R_Us Technical Discussion 7 31-05-2006 17:56
Electronic Compass or other Correct Heading Measurements Ryan Cumings Control System 0 12-01-2005 17:03
Can first go this year without changing a rule nuggetsyl Rules/Strategy 11 07-01-2005 15:36
