Re: question about Transmission axle's
Do you mean the black bearing blocks on the BB transmittions?
Ummm
Im talking about the axle like thing that comes out of the transmission where you put the sprockets on. |
What exactly do you want to know?
Strength? Weight? Capability? Necessity? Color options? |
Example: http://www.fit-senior.com/acatalog/Pillow-block-3.jpg |
yeah thats exactly what I was talking about
Thanks from 2073 ^______________^ |
BaneBots makes a bearing block that is reasonably priced. If you use the dual-motor adapter, the block you remove can be used by adding an inexpensive flanged bronze bearing (1/2" I.D. x 3/4" O.D.) and a spacer or shaft collar to keep it from backing out.
#7
Ok i think you mean how to support the axle on the other side to prevent a cav. load. Well what my team did was fab up at bearing block and mount it on to the frame rail. like this
| Transmission question | Team223 | Motors | 1 | 12-01-2007 13:23 |
| Question about drill transmission specs | ShadowKnight | Technical Discussion | 4 | 18-01-2005 00:14 |
| question about contacts | robot180 | Chit-Chat | 37 | 27-09-2003 22:40 |
| Question about splines | Daishichimaru | 3D Animation and Competition | 2 | 22-01-2003 09:20 |
| Question about wheels | Randy_Ai | Technical Discussion | 9 | 24-01-2002 17:14 |
