Go to Post The world is run by those who show up. - apalrd [more]
Unread 06-02-2007, 19:45
Bigflip2073's Avatar
Bigflip2073 Bigflip2073 is offline
"Chyeah"
AKA: Shane
FRC #2073 (EagleFarce)
Team Role: Electrical
Bigflip2073 is an unknown quantity at this point
question about Transmission axle's
My team was wondering about the supports used to hold the axles on the transmissions
Any Ideas?
P.S.
Sorry its our rookie year and im a new member so i dont know much
T___T
Unread 06-02-2007, 19:47
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: question about Transmission axle's
Do you mean the black bearing blocks on the BB transmittions?
Unread 06-02-2007, 19:53
"Chyeah"
AKA: Shane
Ummm
Im talking about the axle like thing that comes out of the transmission where you put the sprockets on.
Unread 06-02-2007, 19:56
Andrew Blair's Avatar
FRC #0306 (CRT)
What exactly do you want to know?
Strength?
Weight?
Capability?
Necessity?
Color options?
-Sir Francis Bacon
-Albert Einstein
Unread 06-02-2007, 19:58
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Originally Posted by Bigflip2073 View Post
Ummm
On the other side you should mount a pillow block. You can use ones Igus makes, I think BB also makes some, and basically anywhere will have something that will work.
Example: http://www.fit-senior.com/acatalog/Pillow-block-3.jpg
Unread 06-02-2007, 20:03
GMAdan's Avatar
Ok i think you mean how to support the axle on the other side to prevent a cav. load. Well what my team did was fab up at bearing block and mount it on to the frame rail. like this
Unread 06-02-2007, 20:12
"Chyeah"
AKA: Shane
yeah thats exactly what I was talking about
Thanks from 2073
^______________^
Unread 07-02-2007, 18:06
Dick Linn's Avatar
no team (Synergy)
BaneBots makes a bearing block that is reasonably priced. If you use the dual-motor adapter, the block you remove can be used by adding an inexpensive flanged bronze bearing (1/2" I.D. x 3/4" O.D.) and a spacer or shaft collar to keep it from backing out.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Transmission question Team223 Motors 1 12-01-2007 13:23
Question about drill transmission specs ShadowKnight Technical Discussion 4 18-01-2005 00:14
question about contacts robot180 Chit-Chat 37 27-09-2003 22:40
Question about splines Daishichimaru 3D Animation and Competition 2 22-01-2003 09:20
Question about wheels Randy_Ai Technical Discussion 9 24-01-2002 17:14
