Go to Post Everyone here inspires each other and helps them out. That's why FIRST is amazing. - tiffany34990 [more]
Unread 06-02-2007, 22:05
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Guage of PWM/Relay Cables
Does anyone know the actual gauge of the three-pin PWM/Relay cables?
void function(void)
  function();
Unread 06-02-2007, 22:27
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Guage of PWM/Relay Cables
I'm not sure, but I'm guessing about 26 AWM. However, the yellow ones supplied in the kit are probably like 30 AWM.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 07-02-2007, 00:49
dtengineering's Avatar
AKA: Jason Brett
Check out section 8.3.9 at http://www.usfirst.org/uploadedFiles...Robot_RevE.pdf
Particularly check rule 90. The servo wires are 24 AWG. The exception to these rules in the past has been the "Y-connector" cables that allow you to connect two Victors (or Spikes) to one PWM output on the RC. They were 28 AWG as I recall. I don't know as I've seen that exception written in to this year's rules or Q&A forum, so unless I've missed something, I suspect they are not allowed this year.
24 Gauge, three conductor wire can be a bit of a pain to find. I get ours from www.greathobbies.com but you may be able to find a dealer closer to home.
Jason
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
