Go to Post Isn't that what we do here? It seems like no 'controversial' thread is complete until everyone gets a say. - kjohnson [more]
Unread 06-02-2007, 22:45
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
pic: Team 1296 drive train
Unread 06-02-2007, 22:46
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Team 1296 drive train
Interesting. Could you elaborate on how it works.
Mentor 2415
Unread 06-02-2007, 22:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Why did you opt to place your omni-wheels in the center as opposed to the edges like in a traditional holonomic drive?
Unread 06-02-2007, 22:49
Redo91's Avatar
AKA: Justin
I'll see if I can get a newer photo, this one was taken a couple days ago.
The outside wheels work like a normal tank drive, and by adding the center wheel, you get side travel. I am hoping that it will allow the robot to circle-strafe, making travel around the rack easier
Because this is not a normal holonomic drive.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 06-02-2007, 22:50
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Last year when our team was considering omni wheels, I also thought of using this 3-wheel system. The advantage to using 2 forward/back and one side is that typically you need less power going side to side. Having only three wheels eliminates the need for a fourth motor, and saves weight.
Unread 07-02-2007, 08:10
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
just curious-
are your electronics going to be attached to the metal plate at the bottom, or will there be some sort of separation between the two?
Team #996 Programmer/President/Comedy Relief
"Why not stop by the robotics meeting after school today?" -Mr. Murray (enlisting me)
Unread 07-02-2007, 17:39
Redo91's Avatar
AKA: Justin
the electronics are going to be mounted on a plate above the drive
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 14-02-2007, 23:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Yes, but why not place them in a triangular formation every 120º like teams have done with "kiwi-drives" in the past?
http://www.chiefdelphi.com/forums/sh...highlight=kiwi
http://www.chiefdelphi.com/media/photos/16411
Unread 15-02-2007, 00:01
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Ease of programming? Also, If they wanted to have it drive like a normal Tank, and have the side to side 'strafe' controlled by a different means than regular turning... it would be much easier with this configuration.
pic: Team 1538 Drive Train Teaser Jon Jack Extra Discussion 7 06-02-2007 13:59
pic: Team 11's Drive train CD47-Bot Robot Showcase 4 07-03-2004 21:40
pic: Team 60 Drive Train Parts CD47-Bot Robot Showcase 17 07-02-2004 01:58
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
