Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 06-02-2007, 20:23
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
Who has released the Magic Smoke!!!
We finally released our magic smoke that must be released from every robot every year!!! Who else has???
Unread 06-02-2007, 20:24
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Who has released the Magic Smoke!!!
haha we did once or twice lol!! once today to tell the truth thankfully no serious damage occured lol
Unread 06-02-2007, 20:36
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
It does always seem to happen. Usually from the Victors, for some reason, but we've managed to burn out two cameras this year (before you let new members touch the camera, make sure they know that if you plug stuff in wrong, you can break it)
Magic smoke from alligator clips does not count, unless you vaporize the wires themselves (possible.)
Unread 06-02-2007, 20:38
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Define "Magic Smoke"
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 06-02-2007, 20:41
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
I released the magic smoke from a servo durring prototyping, i tried running 2 servos together to perform a task not really suited for a servo ... end result smoking, heating up, melting of plastic. Fun fun fun!
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 06-02-2007, 20:52
Magic Smoke is what makes electrical devices work. It's put inside them when they are manufactured. If it ever escapes, the device stops working.
This is similar to the Magic Noise which makes mechanical devices work. If too much noise comes out of something like a planetary gearbox, it too stops working.
Unread 06-02-2007, 20:57
Originally Posted by FlyingDutchman View Post
why dont you just blow the stuff up if your not going to wire it right
We've had numerous Victors go bad over the years and release magic smoke for no apparent reason. In 2004 we had a case where we heard a pop, smelled magic smoke, saw a spark, but everything seemed to work. (we later discovered that we had only destroyed one of the three transistors)
Be careful mounting components near your metal frame - the frames tend to build up quite a bit of static charge, and FIRST doesn't like people to ground their frames, in order to cut down on shorts. We believe static discharge from the frame into a Victor caused the mysterious spark.
Unread 06-02-2007, 21:26
Actually, there are two types of magic smoke. Magic White smoke winds up in all the electronics, and Magic Black is in anything non-electronic, along with the Magic Noise. If you release the Magic Black, grab the phone and call the Fire Department if there is no fire extinguisher available.
(And then there are the stress sensors--too much stress on you and something stops working. Built in for all electronics; available as an upgrade for mechanical items.)
Unread 06-02-2007, 21:33
MattLi's Avatar
Scrawny Asian Kid
And there's the magic spark that comes after the magic smoke and magic noise. Magic spark is not to be toyed with. Magic spark is very dangerous and should not be in contact with any robot parts and or human parts.
~Royal Air Force
Unread 06-02-2007, 21:40
EnderWiggin's Avatar
EnderWiggin EnderWiggin is offline
07' Co-Team Leader
AKA: Carl Partington
None #0610 (The Coyotes)
EnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud of
I was told not to operate any heavy machinery after inhaling the magic smoke.
Unread 06-02-2007, 22:16
Andrew Blair's Avatar
FRC #0306 (CRT)
This stuff might be a bit different... But still, might be a good guideline.
My opinion- your machinery probably isn't operable if you've let the smoke out...
-Sir Francis Bacon
-Albert Einstein
Unread 06-02-2007, 22:23
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Last weekend I made Magic Smoke on purpose to show the effects of too much current flowing through a small wire to a person on our team that couldn't grasp that idea. I was having too much fun!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 07-02-2007, 00:16
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
We had a little issue with last year's light just before the season started: We were transporting it on a rolling chair, and the way it was wired meant we had to pull a wire to turn it off. However, that pulled wire then had a free end to do anything it'd like to: Including touch the opposite wire's end. Burned a nice hole in the chair and battery. Not to mention the way-cool look of the wire after the event.
The wire literally melted itself into the battery and then re-sealed itself. I stopped it by kicking the chair over, because it'd be pretty stupid to touch anything at that point.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 07-02-2007, 00:31
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I arc'd a globe motor and a genie came out...
i still havent gotten my 3 wishes
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 07-02-2007, 09:55
Molly Stieber Molly Stieber is offline
FRC #0269 (Cooney Tech Robotics)
Team Role: Electrical
Molly Stieber is an unknown quantity at this point
Ha! no magic smoke yet, hopefully i won't see any.
The Magic Blue smoke Cody Carey Chit-Chat 4 17-03-2008 15:56
pic: Magic Smoke Mark McLeod Extra Discussion 15 04-05-2006 15:57
The Magic Smoke... BlueOrion Motors 17 30-03-2004 07:47
Anybody let the magic smoke out? Ryan M. Control System 17 11-02-2004 17:56
Software Magic Smoke Al Skierkiewicz General Forum 17 30-04-2003 12:28
