Go to Post You hang for show; kick for dough. - Travis Hoffman [more]
Unread 28-01-2007, 18:24
CMICK CMICK is offline
FRC #0088
CMICK is an unknown quantity at this point
Removing the stock pulley from the 3" CIM
I'm trying to remove the pulley that comes on the big CIM motor. It looks like it is made for a belt. I know this has been talked about before on this board but I couldn't find the previous post.
I took the set screw out and put a small gear puller on the pulley but it won't budge.
Anybody have a hint for me?
Thanks for any help.
Unread 28-01-2007, 18:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Removing the stock pulley from the 3" CIM
I've heard that it's glued on. Judicious application of heat loosens the adhesive and then your gear puller should work.
Unread 28-01-2007, 18:30
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
This gear puller does wonders. After you take the set screw out from the pulley, you have to heat it up, then use this gear puller to pull the pulley out slowly. Good luck.
in between teams
AKA: Luke Van Oort
Heat up the gear. It is held on by a strong epoxy that weakens a large deal when heated. Last year we successfully used a Bunsen burner to heat it up.
Team 1219: 2009 - Mentor
Unread 28-01-2007, 18:33
FRC #0088
Thanks for the quick replies. I wasn't sure about putting heat to a shaft connected to a motor. I'll give it a try.
Unread 29-01-2007, 03:20
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Assuming you don't want to use the pulley these work great. Just tighten up the bolt and the pulley will crack in half. Doesn't risk damaging the motor with heat or any pulling.
You can get them at most hardware stores like sears. Home Depot might even have them. Look under nut splitters. Best of all they are CHEAP.
http://www.harborfreight.com/cpi/cta...emnumber=40929
Unread 29-01-2007, 07:43
FRC #0088
I got it off this morning.
I applied my gear puller pretty tight, then applied the smallest amount of heat from a propane torch and the gear began to slide. Applied a little more heat and pulled the gear off the rest of the way by hand, wearing gloves of course.
Unread 07-02-2007, 00:16
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Exclamation Re: Removing the stock pulley from the 3" CIM
BE VERY CAREFUL WITH HEAT!!! Just tried this method and both motors are now permanently damaged (The two motors arrived yesterday). The heat apparently loosened the adhesive that locks the armature to the shaft, and the shafts moved inward about 3/16". A Mapp gas torch was used to heat the pinion, and then a pin punch was used to hammer the shaft from the pinion. It didn't work. I then became frustrated and hammered the pinion on an anvil, which did work. The pinion to brittle enough to crack it with a hammer. I highly reccomend breaking the pinion to remove it rather than the application of heat, which may prove disastrous.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 07-02-2007, 01:19
FRC #0254
That is exactly why we use the nut splitter. Takes 30 sec and there is little to no risk of damage to the motor/shaft. Its well worth the $5-10 for the tool.
Unread 07-02-2007, 01:27
Gabe's Avatar
I like using the nut splitter, and have used it before. Just that this time I did not have it around and I really needed it then and there, so I tried using heat.
How to remove pulley from CIM motor de_ Motors 14 01-02-2006 20:49
big CIM pulley Rickertsen2 Motors 1 18-01-2006 11:41
Large CIM Motors - Removing the sprocket PuiChi Motors 5 13-01-2006 16:01
pic: My vote for the best design from the team spirit "drawn" in the stands. CD47-Bot Extra Discussion 4 07-09-2004 00:19
Removing encryption from the pdf's Mike Soukup General Forum 6 08-01-2004 17:43
