Go to Post IMHO if it was legal a peg leg would be better than a caster. - Edoc'sil [more]
Unread 07-02-2007, 07:43
RedOctober45 RedOctober45 is offline
Mentor - Embedded Software Engineer
FRC #0291
RedOctober45 will become famous soon enoughRedOctober45 will become famous soon enough
Send a message via AIM to RedOctober45
Camera Issues
Hey guys. I have a question about getting the camera to work properly. I am a student mentor who helped last year and this is the first real year using the camera for us, since its almost needed. It works in testing o.k. so far but I was messing around with the camera java GUI one day and it locked up on me and crashed, and when I recovered, the camera would not connect to it or even run when I ran the default code. It is powered on and all but won't connect to the java app nor run with default code. I am hoping that the drivers on the camera aren't corrupt, any suggestions? Thanks alot guys.
Unread 07-02-2007, 07:55
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Camera Issues
Have you checked your backup battery voltage? We have found that most communication problems are caused by a drained battery, even though the camera may appear to be OK (LEDs on, etc...).
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 07-02-2007, 08:25
joesmomh00haha's Avatar
joesmomh00haha joesmomh00haha is offline
sneeble
AKA: sneeble
FRC #1841 (Crazy Bred)
Team Role: Mascot
joesmomh00haha is infamous around these parts
Talking Re: Camera Issues
well the solution to that problem should be in the manual. it might be in the cmu camera2 section.
Unread 07-02-2007, 08:26
Anubuss's Avatar
Anubuss Anubuss is offline
AKA: Brian Dixon
FRC #0085 (B.O.B. (Built On Brains))
Anubuss will become famous soon enoughAnubuss will become famous soon enough
Send a message via Yahoo to Anubuss
Re: Camera Issues
The camera might have simply just locked up on you, I know it did for me a few years ago when I played with in in my junior/senior years, if memory serves me right, all you really need to do is reset the camera, and re-open the app. I was good to go after that and you SHOULD be too if we had the same problems.
In loving memory of our dear mentor Steve Yasick, team 85 will carry on.
Unread 07-02-2007, 10:34
Re: Camera Issues
Step one: check the connections. In this case, it also means to make sure things are not connected when they shouldn't be. Specifically, you can't use the camera with both a DB9 serial connection to a PC and a "pwm cable" connection to the robot controller at the same time.
Unread 08-02-2007, 15:59
sneeble
AKA: sneeble
Team Role: Mascot
Re: Camera Issues
i still think the solution is in the manual.
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Camera Issues -- So close yet so far. team66t-money Programming 34 04-05-2005 23:17
Camera issues Todd Programming 0 16-02-2005 19:06
3D Studio Issues super_matt_250 3D Animation and Competition 6 14-02-2003 07:22
