Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
Unread 07-02-2007, 09:08
buddy.smith buddy.smith is offline
Master Control
FRC #1795
buddy.smith is an unknown quantity at this point
Re: Vex encoders/Interrupts
Originally Posted by Andrew Morris View Post
Switching to an FRC controller shouldn't affect anything unless you change the code because the FRC controller and the VEX controller have the exact same microchips and are just packaged differently.
It seems that the interrupts and encoders work on the First controller, but not the Vex. I'm not sure why.
Also, I was wondering how you are powering the Victors and motors because you don't appear to have a 12v FRC battery on the robot and running them off a 7.2v VEX battery could be causing your uneven drive problems if they are made to run off 12v.
I checked the datasheet of the Victor 884s and they're okay with 7.2V. I do have a second Vex battery just for the 884/motors.
--buddy
Interrupts JSonntag Programming 1 14-01-2006 12:43
Vex navigation with ultrasonic and encoders GlennGraham Electrical 4 13-01-2006 12:58
VEX Optical Shaft encoders in FRC sanddrag FIRST Tech Challenge 8 04-10-2005 07:52
Encoders, interrupts, and edge-triggering issues Alan Anderson Programming 6 11-03-2005 16:06
Interrupts CyberWolf_22 Control System 3 12-01-2004 21:46
