Go to Post "Scientists investigate that which already is; Engineers create that which has never been." - Albert Einstein - JamesCH95 [more]
Unread 07-02-2007, 10:34
HellBoy HellBoy is offline
FTC #2230
HellBoy is an unknown quantity at this point
Autonomous mode
Where are the variables that are used in autonomous code declared?
Unread 07-02-2007, 12:06
kitscuzz's Avatar
kitscuzz kitscuzz is offline
Not alotta posts
AKA: Kit
FRC #1389 (Worst Case Scenario)
kitscuzz will become famous soon enough
Re: Autonomous mode
Just make sure you declare them outside of the "while(autonomous_mode)" loop and everything should be fine.
Unread 07-02-2007, 18:17
dude_brd's Avatar
dude_brd dude_brd is offline
ronaldinho
FRC #1484 (hoggzilla)
dude_brd is an unknown quantity at this point
need help programing on our controls
i need help on how to program our controls using labview 8.2
Unread 07-02-2007, 18:19
dude_brd's Avatar
ronaldinho
Re: need help programing on our controls
i need help programing our controls using labview 8.2
Unread 07-02-2007, 18:22
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Autonomous mode
You might want to delete your double-post because people will see it and negative-rep you...
You don't straight-up code with LabView. You either use easyC or MPLAB to code the controls. I don't know LabView well enough to instruct you on how to use it, but there are plenty of threads on how to program around here.
JBot
Aren't signatures a bit outdated?
Autonomous Mode fallen751 Programming 14 09-02-2007 00:28
Autonomous Mode Slick Programming 22 01-02-2007 19:26
Autonomous Mode Yellow Eyes Programming 2 18-02-2004 21:16
Autonomous Mode tysonwormus Rumor Mill 11 08-01-2004 22:59
autonomous mode Stephanie Programming 2 25-01-2003 19:57
