Go to Post If I run into some of your team's student coaches/drivers on the field of battle someday, I still might ask 'em what they're doing after high school. :) - Ken Patton [more]
Unread 07-02-2007, 10:38
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
need help with power dist block & maxi bkr
I see a list of # of wires per block, like 1 #6, 3-#10s. I take it that means 3 #10s in the same hole on the same block?
About Maxi breaker panel: I have #6 from power block to one side of maxi breaker, the other side of maxi breaker has #6 to the other breaker panel. Is that allowed? or do I need #6 from power block to other panel?
Unread 07-02-2007, 10:44
Electrical Engineer
Rookie Year: 1995
Re: need help with power dist block & maxi bkr
Steve,
Look at this drawing.
Mike
Mike Betts
As easy as 355/113...
Unread 07-02-2007, 12:26
AKA: Dr. Brooks
no team (WRRF)
All of the connections to the black ground block, and similarly the red 12 volt block, are equivalent. There is no input side, and output side. Your wiring of the #6 12 volt wire through a single power block to a #6 wire on the other side going to a breaker panel is correct, and smart, because it minimizes the voltage drop to the breaker panel. If you use a second breaker panel, you have to use a second red power block. Choose the breaker panel with the least load for this to minimize voltage drop on the yellow jumper.
For the ground power block, you can put multiple wires in a given terminal as long as you satisfy the wiring rules in the documentation that was provided by FIRST. FIRST provided (from the manufacturer) the power block documentation that indicates up to 3 #10 wires are allowed in the power block. Use the same strategy for the high current wiring as the positive side, arranging the high current connections so the amount of current across the jumper is minimized.
If you feel that there is a conflict between the power block documentation, provided by FIRST, and the written rules and the power distribution diagram, you can ask a question on the QandA.
<<<I have #6 from power block to one side of maxi breaker, the other side of maxi breaker has #6 to the other breaker panel. Is that allowed? or do I need #6 from power block to other panel?>>>
Power feed wires must go from the power block to the breaker panels, not through the breaker panels.
Eugene
Last edited by eugenebrooks : 07-02-2007 at 17:18. Reason: Miss-read an error in the post.
Unread 07-02-2007, 14:22
Steve,
The original robot electrical diagram was incorrect. You have that early version. Please see the revised version in the link that Mike posted.
Unread 07-02-2007, 18:07
FRC #1277
Thanks to all and to all a good night!
Modifying 40 Amp maxi fuse block kborer22 Electrical 18 23-01-2007 10:12
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
