Go to Post Dont give up, because that is when you lose what you have. FIRST is the best experience that I have had throughout my entire life and there is no way ANYONE can make me quit FIRST. - Arefin Bari [more]
Unread 07-02-2007, 10:33
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Pneumatics and air pressure
I have a very stupid question, but it can help us a lot.
Should the pressure rate of the air in the parts we have be at least 125 PSI or up to 125 PSI?
Thank you very much
Team 2230
Unread 07-02-2007, 10:37
geo's Avatar
geo geo is offline
A Nuke Would Do The Job!
FRC #0865 (WARP 7)
geo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the rough
Re: Pneumatics and air pressure
Up to 125 psi.
2006 Greater Toronto Regional Winner!(with 1114 & 1503)
2002 Canadian Regional Winner!(with 610 & 781, our rookie year )
Unread 07-02-2007, 10:48
Electrical Engineer
Rookie Year: 1995
Thank you very much
Team 2230
It should be less than 120 PSI on the high side of the pressure regulator and less than 60 PSI on the low side.
Mike Betts
As easy as 355/113...
Unread 08-02-2007, 22:30
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Thank you very much
Team 2230
The RATED pressure of anything you use must be at least 125 PSI. That means it has been tested and is acceptable to use up to that pressure.
You can have up to 120 PSI on the high side (compressor and storage tank) of the regulator.
You can have up to 60 PSI on the low side (solenoids and cylinders) of the regulator.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Pneumatics - what do we do with exhaust air? devaaki Pneumatics 13 10-02-2007 11:30
Will air pressure in venue affect path of ball? (was: DOES ANY ONE KNOW ????) RoboDriver Technical Discussion 5 17-01-2006 23:02
How to make Pneumatics use less air sanddrag Pneumatics 1 16-02-2004 15:50
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
Pneumatics-Extra Air Tanks archiver 2001 2 24-06-2002 00:13
