Go to Post I would be thankful to just participate in champs, I would be happy with just that. - Brandon_L [more]
Unread 07-02-2007, 14:29
Re: MPLAB/c18 not creating a .hex file
Could be the "Output Directory" is set in
Project -> Build Options... -> Project
to be some place other than the current directory.
Unread 08-02-2007, 18:13
Cheezmeister Cheezmeister is offline
FRC #0871
Cheezmeister is an unknown quantity at this point
That wouldn't cause the linker not to even output "cod to hex converter" (or whatever the exact wording is...) though, would it?
Unread 09-02-2007, 09:50
I was thinking that if no COFF is evident in the directory to be passed to mp2hex.exe, then MPLAB would automatically skip that step or mp2hex.exe would just stop and not display any message.
I encountered this same issue with Smithtown a couple of year's ago and I'm trying to remember how we fixed it. They had played around a lot with the settings and had specified where intermediate directories, etc. were located instead of taking the installation defaults.
It may have been a matter of taking all the defaults or reinstalling MPLAB/C18 to get all the default settings back, but based on your experience of it happening with some files and not others, I suspect we must have recreated the projects as well to correct the project specific settings.
You can run mp2hex.exe from a command line in case it gives you any more useful information.
Unread 11-02-2007, 16:13
FRC #0871
Thumbs up Re: MPLAB/c18 not creating a .hex file
OK, I'll give that a shot when I'm back in school tomorrow, Mark
Unread 15-02-2007, 15:01
FRC #0871
Well, running mp2hex.exe did nothing....
...because the path was too long -_- The projects that weren't getting hexes made were the ones whose paths were longer than 62 characters...always read carefully
Thanks for the help, all.
creating hex file seanl Programming 4 03-02-2007 22:08
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
hex file garbage? sciguy125 Programming 2 04-07-2005 23:04
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
