Go to Post We draw the line when our students are more affectionate towards the tools rather than eachother. - ksafin [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 07-02-2007, 15:50
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Gloves
I would like to point out the “remove jewelry” in Sean’s post above. This also includes rings on your fingers not just dangling jewelry.
WARNING: THIS STORY MIGHT GROSE SOME PEOPLE OUT! DON’T READ IF YOU ARE SQUIMISH!
Here is a personal example: When I was in high school I worked for a flight school at a small local airport as the shop helper kid. It was a dream high school job because I loved airplanes. One day one of the A&P mechanics was working on the engine of a helicopter in the hanger and was just standing on one of those little flip out foot rests halfway up the side of the fuselage. His foot slipped and he went sliding down the side of the helicopter which wasn’t a large drop but his wedding ring got stuck on something (a screw or rivet or something) and due to the falling weight of his body caused the skin on his ring finger to be pealed off sort of like a sock. That left an impression on me.
Unread 07-02-2007, 18:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Gloves
The reasoning for no gloves while using power tools (or anything that spins really) is simple. Gloves are stronger than human skin. If your finger hits a grinding wheel for example, the worst that will probably happen is you lose a little chunk of skin. If you are wearing a glove and hit the grinding wheel, you could break and or/lose fingers quite easily. I did an experiment once on a large disc sander (16" or so). There was approximately 3/8" gap between the wheel and the table. The sander had been turned off for about 3 minutes. It was still spinning down. It had good bearings and a large flywheel effect. Anyhow, I took a shoe, and stuck it right up against the wheel (bare steel wheel, not even any sanding disc). It sucked the whole shoe about half way in, into this 3/8" wide gap faster than I could blink. I mean, think about how thick a shoe is. And there wasn't even a motor powering this thing at the time. This machine is capable of taking a whole hand without a doubt. And this machine is not too different than something many teams probably use. So, don't wear gloves while grinding (yes, it gets hot, yes, that's what water is for), sanding, drilling, working on sprockets and chains or gears, etc.
We did gloves FIRST? rufu5 General Forum 30 17-03-2004 16:03
Control gloves Jeff666 General Forum 0 01-04-2003 19:15
