Go to Post "FIRST isn't what it used to be anymore. It makes me upset and it makes me question many things." - Arefin Bari [more]
Unread 17-01-2007, 08:41
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: CMUCam, Easy C, and Labview
easyC doesn't use the camera servo ports it uses PWM ports 10 & 11 in the 2007 kickoff code which are defines so you can easily change the port number. We are getting ready to release an update for PRO that fixes a few issues and we will probably remove the servo block from the camera stuff.
I'm also working to add searching to my drive code and dual light targeting. But, Team 40 took apart my kitbot so I'm currently without a test bed.
Hopefully we will have a new chassis ready to test on today.
Originally Posted by MattD View Post
Right, as far as I can tell the easyC code depends on having the servos controlled via the camera board and not the RC. However, the 2007 kickoff demo could be a good starting point, as it does have tracking code that controls the servos via the RC.
Since my team has opted to use easyC, we ended up porting Kevin's streamlined tracking code rather than basing from the aforementioned demo code, however. It still needs to be tweaked a bit, but it seems to work fine.
Unread 17-01-2007, 09:33
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Yes, I know that the 2007 kickoff code uses PWM outputs 10 and 11 on the RC to control the servos by default, but I'm talking about the functions built into easyC, like SetServoTracking(). Does that one control the servos via the RC also? If so, how do you set which PWM outputs to use? It seems to me like that was intended for use with the servos connected to the camera.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 17-01-2007, 10:25
Kingofl337's Avatar
AKA: Adam
The SetServoTracking command is the same as SetPWM but for the camera servos. If you want to have the camera auto target like it would if the servos were plugged into the camera then do this.
void Initialize ( void )
     InitCamera ( 1 ) ;   //Initialize camera for target color
     SetServoTracking ( 1 , 1 ) ; // Sets camera servos to autotrack target
     StartCamera ( ) ; // You need to restart the camera if you change camera servo settings
void OperatorControl ( void )
      unsigned char ServoPan;
      unsigned char ServoTilt;
      while ( 1 )
            // Checks the where the camera wants the servos to be pointed.
            CaptureTrackingData ( 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , &ServoPan , &ServoTilt ) ;
            SetPWM ( 1 , ServoPan ) ; // Moves the servo for Pan
            SetPWM ( 2 , ServoTilt ) ; // Moves the servo for Tilt
Unread 24-01-2007, 14:55
sniggel sniggel is offline
FRC #2051
sniggel is an unknown quantity at this point
our easy c demo 2007 code does not work. are there steps we are missing? Kevin's code works fine. I saw a post about setting the robot to autonomous, but we are using a testbed, not a robot. We do have the servos connedted to pwm 10, 11 so this is not it. Any thing else we need to do?
Unread 24-01-2007, 15:56
Kingofl337's Avatar
AKA: Adam
Do you have the OI in Autonomous mode?
Unread 24-01-2007, 16:10
FRC #2051
If i read correctly we set the team number to zeros and that would set the oi to autonomous, is there something else we missed. The team number was the only jumpers we changed
Unread 24-01-2007, 16:14
Kingofl337's Avatar
AKA: Adam
Yes, your team should have a dongle. It plugs into the competiton port and selects between autonomous and operator control. It also allows you to disable the robot.
Here is the unit AndyMark Makes: http://www.andymark.biz/am-0016.html
Setting the team number to zero may work as well, but I've never tested that.
Unread 24-01-2007, 22:50
FRC #2051
is the dongle the only way to get the code working? It looks like it could take some time to get that in, and I saw the alternative is to make one, which I will have our electronics team look at. I thoght I saw somewhere a mention about manually changing jumpers on the Interface unit to get the autonomous to work. Can it be done without the dongle?
thank-you
Unread 25-01-2007, 10:11
Kingofl337's Avatar
AKA: Adam
They are pretty easy to make the hardest thing to find is a DB15 connector because Radio Shack doesn't normally stock them anymore.
Well you could just copy the block from autonomous to operator control.
Unread 25-01-2007, 22:52
FRC #2051
thankyou were were able to get the autonomous connection up and running
The autonomous code is being called, but since we dont have our motors hooked up nothing is happening. The camera stays at red, which I figure means it finds the light but cant do anything till we get our motors hooked back up. I do have a question, I thought I saw something about needing a graphics emulator for the code to work, now I cant find where I saw that. Do we need to download and emulator somewhere to get the graphics display running correctly?
Unread 25-01-2007, 22:55
Kingofl337's Avatar
AKA: Adam
No, if you downloaded the code from Http://www.intelitekdownloads.com/easyCPRO
You use the graphics display. Just open the terminal window and check off "Graphics Display"
Also in Sample Programs we have a neat camera test program. That shows you the box of what the camera sees.
Unread 07-02-2007, 15:03
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
When porting Kevin Watson's streamlined code... did you import every file, or only the ones pertaining to the camera?
Unread 07-02-2007, 15:55
hal hal is offline
FRC #2212
hal is an unknown quantity at this point
I've come back to this thread after about 3 weeks, and I think I see something here that I didn't realize before. Are you saying that SetServoTracking can control the camera servos connected to PWM1 and PWM2 and thereby cause the camera to track the green light, just like Kevin's MPLAB code does? If that is do, and I convert the values returned by CaptureTrackingData to degrees, I should be able to control the robot drive motors. Is that correct?
      while ( 1 )
Unread 07-02-2007, 22:20
Kingofl337's Avatar
AKA: Adam
The servos just center the camera on the object its tracking they don't drive the robot. So, you can use the servo's to figure out distance and turn angle they don't drive the robot directly.
And yes this will have the servo's autotrack for the camera. You can also look at the code used at kickoff at www.intelitekdownloads.com/easyCPRO
Labview CMUcam demo problem Windward LabView and Data Acquisition 19 11-08-2007 02:33
Problems with CMUcam & LABView Daniel_H LabView and Data Acquisition 1 30-01-2006 12:07
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
