Go to Post Students, mentors, schools, corporations, teams, and communities - they are all critical to the success of FIRST. . - dlavery [more]
Unread 02-07-2007, 04:11 PM
Barchechath Barchechath is offline
AKA: Ben Barchechath
FRC #1580
Barchechath is an unknown quantity at this point
Send a message via ICQ to Barchechath Send a message via MSN to Barchechath
Watchdog
Hi (again) !
I am trying to understand what is "watchdog", how to use "watch dog" and what it does?
Thank you all!
Ben Barchechath
Unread 02-07-2007, 04:23 PM
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Watchdog
If it's in reference to what I think it is, you are referring to the watchdog timer in our robot controller.
Basically, our user processor has to get data from the master processor when it comes in, and the user processor has to spit the new data outputs (to the motors, Spike relays, etc.) to the master processor. If the user code takes too long between grabbing data and spitting it back, the "watchdog" timer freezes our processor and flashes the "Code Error" light--it's red, so it's known as the "red light of death".
The user code doesn't have to do anything special to use the watchdog timer; it's just there--a feature of the IFI-proprietary master code loaded on the robot controller. We don't turn it on or off or set the delay; it's just there. If you're programming in easyC, don't worry about a thing. If you're programming in MPLAB, try not to put for loops or other extremely time-consuming tasks in your code, and if you do, make sure to thoroughly test it before trusting it.
Don't worry about the watchdog timer; it'll only shut your code down if you've written code that takes too long to execute.
And if you need more help, as always, post back and we'll try to help.
JBot
Aren't signatures a bit outdated?
Unread 02-07-2007, 05:03 PM
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Watchdog
FYI, if you're reading through the PIC reference manual and/or datasheet, there are references to a watchdog timer in the processor. This is not the same thing as the "watchdog" JBotAlan discussed. (I've never heard the term applied to the master processor before this year.)
Unread 02-07-2007, 05:22 PM
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Re: Watchdog
Well, I knew that the master processor would shut us down if we took too long, and I've heard of watchdog timers on PLCs and such, so I assumed that's what IFI called it. I haven't actually seen that term referring to the master processor either, but...that's what it is.
JBot
Unread 02-08-2007, 12:19 AM
Jared Russell's Avatar
Taking a year (mostly) off
Re: Watchdog
More generally, a "watchdog" is simply a timer that needs to be "serviced" every so often or the system activates some sort of fail-safe mechanisms. In the world of engineering, we often use watchdogs to monitor systems of several processors or devices - a pulse is periodically sent out to all devices, and if a response is not received in a given window of time, then the system assumes that the device that failed to respond has stopped working, and acts accordingly.
In FIRST, the master uP and user uP indeed have a watchdog-like relationship.
Unread 02-10-2007, 04:42 PM
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Watchdog
This can cause problems in some cases. namely, don't make my mistake i put a puts("a"); inside the encoder code that didn't work. it told us when they fired, but then the interrupts backed up too much and the watchdog shut us down. To make a long 30 minutes of hair pulling short, DON'T PRINT INSIDE THE INTERRUPTS!!!
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 02-10-2007, 08:05 PM
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Re: Watchdog
Oh yeah, you've just discovered how slow printing is when compared to interrupts. Go as fast as you possibly can when inside an interrupt; you *will* see some strange behavior if you don't. A ++ of a variable is about all I will do inside an interrupt handler.
