Go to Post FIRST's awesomeness cannot be described in numbers. - Shinglei [more]
Unread 07-02-2007, 17:19
dtengineering's Avatar
AKA: Jason Brett
Re: anybody have a schematic for air tanks? (was: i have a question)
Originally Posted by Mike Betts View Post
Jason,
Some comments on your advise...
As per rule <R101> you may not remove the Nason Pressure Switch from the robot. It must be connected to the RC and must shut off the compressor (at about 115 PSI) before the pressure relief valve actuates (about 125 PSI).
As per rule <R102> you are not allowed to adjust the pressure relief valve.
Regards,
Mike
Thanks... my advice did ignore R101... it was written late at night, but I have edited the original post to highlight this oversight. As for R102, however, our pressure relief valve (for the first time, I might add) was not tight when it arrived and would release at less than 100 psi. It was necessary to adjust it to return it to FIRST specs, and it is now tightly locked in place at 120-125psi.
Jason
Unread 07-02-2007, 17:56
Electrical Engineer
Rookie Year: 1995
Jason
Jason,
You (and anyone else having this problem) should post this information to the FIRST Q&A. They need to realize that this is happening and revise the rule accordingly.
Mike
Mike Betts
As easy as 355/113...
Does anyone have a schematic for the operator's panel? DHarris Technical Discussion 1 28-01-2006 10:46
Anybody have a code for an autonomous mode to go to the 50 point bar???? and... chaoticprout Programming 9 06-11-2004 12:22
Anybody have ANYTHING from SPBLI or Philly? DaBruteForceGuy Regional Competitions 2 07-04-2004 22:33
Looking for gears - anybody have these? JamesJones Technical Discussion 4 04-02-2004 14:32
does anybody have pictures from 1999? Alex Cormier General Forum 6 13-01-2004 12:25
