Re: Can Victors work as ESCs without all of the other electronic components?
Is it as easy as buying one of those circuits, attacing a pot to it, on the other end the pwm and to the victor?
i don't think that would be to safe, if the duty cycle(i think that is what it is called) is below 50%, the motor will go backwards. you might want to use a small microcontroller for it, i would recommend an arduino, which is based off an ATmega8
It's not quite that easy. You'll need a couple of capacitors and resistors, I'm sure. Search around for 555 circuits, or pick up a copy of Forest Mims' timers and op-amps notebook. |
You can find a wealth of info on the IFI FAQ for the Victors here...
http://www.ifirobotics.com/forum/vie...4742c7 8d25be From that page... Here are the required input control signal characteristics of the PWM input signal for the Victor and the PWM Outputs for our RC units: Period for the Mini RC PWM Output: 17.0 ms. Period for the FRC Robot Controller PWM Output: 26.2 ms. Maximun Rate: 120 Hz. Pulse width: 1 - 2 ms As the positive pulse width varies from about 1 ms to 2 ms, the Victor will range from Full Reverse to Full Forward. The Victor should be in Neutral at about a 1.5 ms pulse width. |
On a side note, please put a cutoff switch somewhere between the battery and motors that's easily accessible. A rampant "FIRSTmobile" could be a very scary thing... JBot |
RobotLogic sells something called the IMX-1, which acts as a PWM signal booster, which runs inline with a PWM cable to operate Victors with standard RC equipment. It also mixes signals for one-stick driving, and uses a spare RC channel for inverted controls, which is useful in combat robotics if you get flipped over (assuming your robot can drive inverted), or to make backwards driving easier.
http://www.robotlogic.com/product_imx1.html |
#7
Do a google search on 'servo tester'. It is a relatively simple circuit.
Also certain PIC type processors have PWM on board circuitry. Try a search also on PIC PWM. |
#8
If you choose to use a supplementry circuit to generate the PWM signal, be sure to familiarize your self with the calibration routine. It is likely that a custom circuit will not output values that match those the Victor expects from the IFI equipment. Calibration will force the victor to scale the values, allowing you to set neutral, reverse and forward to values the circuit can produce.
This also goes for anyone using a Victor with hobby R/C gear. The factory calibration makes the assumption of using a PC joystick and an IFI control system. With out those, the factory calibration isn't even close. -Local |
#9
If you give more info on the project it would be easier to help. For example I can tell you to make an Hbridge, but I don't know if that would fit the project. Or you can go to somewhere like pololu.com and buy there servo controller and buy a basic stamp and just use the serout command to send serial data to it. If you have the money for that i would say that would work just fine. |
| How Can I aim at the Vision Target Faster but without overshooting? | NextPerception | Programming | 21 | 20-02-2007 11:26 |
| Can we use old Victors | KMAC42 | Electrical | 5 | 26-01-2007 12:37 |
| Vex Components For Other Robots | Robots_R_Us | Technical Discussion | 7 | 31-05-2006 17:56 |
| Electronic Compass or other Correct Heading Measurements | Ryan Cumings | Control System | 0 | 12-01-2005 17:03 |
| Can first go this year without changing a rule | nuggetsyl | Rules/Strategy | 11 | 07-01-2005 15:36 |
