Re: Can Victors work as ESCs without all of the other electronic components?
i don't think that would be to safe, if the duty cycle(i think that is what it is called) is below 50%, the motor will go backwards. you might want to use a small microcontroller for it, i would recommend an arduino, which is based off an ATmega8
It's not quite that easy. You'll need a couple of capacitors and resistors, I'm sure. Search around for 555 circuits, or pick up a copy of Forest Mims' timers and op-amps notebook. |
You can find a wealth of info on the IFI FAQ for the Victors here...
http://www.ifirobotics.com/forum/vie...4742c7 8d25be From that page... Here are the required input control signal characteristics of the PWM input signal for the Victor and the PWM Outputs for our RC units: Period for the Mini RC PWM Output: 17.0 ms. Period for the FRC Robot Controller PWM Output: 26.2 ms. Maximun Rate: 120 Hz. Pulse width: 1 - 2 ms As the positive pulse width varies from about 1 ms to 2 ms, the Victor will range from Full Reverse to Full Forward. The Victor should be in Neutral at about a 1.5 ms pulse width. |
| How Can I aim at the Vision Target Faster but without overshooting? | NextPerception | Programming | 21 | 20-02-2007 11:26 |
| Can we use old Victors | KMAC42 | Electrical | 5 | 26-01-2007 12:37 |
| Vex Components For Other Robots | Robots_R_Us | Technical Discussion | 7 | 31-05-2006 17:56 |
| Electronic Compass or other Correct Heading Measurements | Ryan Cumings | Control System | 0 | 12-01-2005 17:03 |
| Can first go this year without changing a rule | nuggetsyl | Rules/Strategy | 11 | 07-01-2005 15:36 |
