Go to Post I think we are having that "hard fun" that Woodie Flowers keeps talking about. - OZ_341 [more]
Unread 07-02-2007, 19:48
CraigHickman
Posts: n/a
pic: 114 2 speed Gearbox
Unread 07-02-2007, 19:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: 114 2 speed Gearbox
Out of curiousity, where did you buy the pinion gears that are mounted to each CIM?
--Madison--
...down at the Ozdust!
Unread 07-02-2007, 19:50
CraigHickman
Posts: n/a
The pinions are the pinions from the previous years KOP, also available from AndyMark in the same size, only de-hubbed.
Unread 07-02-2007, 19:56
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
I love how you use aluminum hex stock as your gearbox spacers. Also, I'm guessing you're using this gearbox to direct drive your wheels, right?
Unread 07-02-2007, 20:00
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Nice and shiney, I like it. I look forward to seeing that gearbox attached to your acual robot. I looks like it would make for a strong drive train.
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 07-02-2007, 20:12
Madison's Avatar
FRC #0488 (Xbot)
Doesn't that make them illegal as per <R28>?
<R28> COTS ITEMS that are generally available may be used on the ROBOT. COTS ITEMS from
ROBOTS entered in previous FIRST competitions or COTS ITEMS that are no longer
commercially available may be used under the following conditions:
° The item must be unmodified, and still in its original condition as delivered from the
VENDOR
° The item must not be a part custom made for the FIRST competition and provided in a
previous FRC Kit Of Parts (e.g. 2006 FRC transmissions, custom-made motor couplers,
custom sensor strips, IFI CMUcam II modules, etc. are not permitted)
° The item must satisfy ALL of the rules associated with materials/parts use for the 2007
FIRST Robotics Competition
Specifically, it doesn't satisfy the conditions set forth in the second bullet, given that the gearboxes from which it came and their components were made for FIRST.
If so, at the very least, it's an easy fix. The gears available from AndyMark lack only the hub and set screw but are otherwise the same, so it's a quick switch. Hold them in place with some 5/16" self-locking retaining clips and you're in business.
--Madison--
Unread 07-02-2007, 20:36
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Thumbs up Re: pic: 114 2 speed Gearbox
Looks good. What's the weight with the motors and piston?
I also can't figure out where the chains are supposed to go. I should probably go take a look at your model again.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 07-02-2007, 20:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
You can buy those pinion gears from Boston Gear (with the hub), so it shouldn't be an issue.
Unread 07-02-2007, 21:06
Madison's Avatar
FRC #0488 (Xbot)
Provided you key them somehow, this also a viable solution.
In any case, the gearboxes themselves look good. I like symmetry in design a lot and most gearboxes seem to be asymmetrical.
--Madison--
Unread 07-02-2007, 21:29
CraigHickman
Posts: n/a
I thought about this... not sure what we'll end up doing about it.
The middle wheel will have two sprockets on the sides of the wheel, which will run chain to the other wheels. See here: http://www.chiefdelphi.com/media/photos/26243
Unread 08-02-2007, 08:02
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I bought 14T gears from Motion Industries. I also bought an 8mm reamer and a 2mm broach set to modify them to the CIM.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 08-02-2007, 15:02
Halo4life's Avatar
Halo4life Halo4life is offline
AKA: Brock
FRC #1254 (Entropy)
Halo4life is an unknown quantity at this point
Send a message via AIM to Halo4life Send a message via MSN to Halo4life Send a message via Yahoo to Halo4life
It Looks Sweet. What are the gear ratios?
Unread 25-02-2007, 18:17
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
I like how you faced out the inside of the gearbox plate How heavy is it?
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 25-02-2007, 19:41
CraigHickman
Posts: n/a
The total weight for the whole assembly, with motors and shifters and all that is too heavy... 10 pounds too heavy, to be exact.
But I'm really happy with the performance. It shifts nicely, with a small quirk on the left side (we're fixing that in programming).
pic: 114 Gearbox CAD CraigHickman Extra Discussion 7 26-01-2007 23:37
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
pic: 114 2 speed Coaxial Crab Drive CraigHickman Extra Discussion 14 27-07-2006 10:08
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
