Go to Post More resistors Igor! - BitTwiddler [more]
Unread 07-02-2007, 20:12
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: 114 2 speed Gearbox
Originally Posted by 114ManualLabor View Post
The pinions are the pinions from the previous years KOP, also available from AndyMark in the same size, only de-hubbed.
Doesn't that make them illegal as per <R28>?
<R28> COTS ITEMS that are generally available may be used on the ROBOT. COTS ITEMS from
ROBOTS entered in previous FIRST competitions or COTS ITEMS that are no longer
commercially available may be used under the following conditions:
° The item must be unmodified, and still in its original condition as delivered from the
VENDOR
° The item must not be a part custom made for the FIRST competition and provided in a
previous FRC Kit Of Parts (e.g. 2006 FRC transmissions, custom-made motor couplers,
custom sensor strips, IFI CMUcam II modules, etc. are not permitted)
° The item must satisfy ALL of the rules associated with materials/parts use for the 2007
FIRST Robotics Competition
Specifically, it doesn't satisfy the conditions set forth in the second bullet, given that the gearboxes from which it came and their components were made for FIRST.
If so, at the very least, it's an easy fix. The gears available from AndyMark lack only the hub and set screw but are otherwise the same, so it's a quick switch. Hold them in place with some 5/16" self-locking retaining clips and you're in business.
--Madison--
...down at the Ozdust!
pic: 114 Gearbox CAD CraigHickman Extra Discussion 7 26-01-2007 23:37
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
pic: 114 2 speed Coaxial Crab Drive CraigHickman Extra Discussion 14 27-07-2006 10:08
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
