Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Unread 07-02-2007, 20:25
Nicole_Ypes Nicole_Ypes is offline
Nicole Ypes
FRC #1547 (Waldo)
Nicole_Ypes is an unknown quantity at this point
Send a message via MSN to Nicole_Ypes
Exclamation Potentiometer Problems
My team is having trouble with our potentiometer. We have all three leads conected and we have tested them for voltage and resistence, and both turned up to be fine. We have checks everything over, but we just can't get the values to print to screen. We are using easyc pro but I typed out the code:
#include "Main.h"
void main( void )
unsigned int PotValues;
while (1)
PotValues = GetAnalogInput(1);
PrintToScreen("%u\n ,(int)PotValues);
Can anyone help me here? This just does not seem to be working, We compared this programto those of last years but still has not turned anything up, we also tried using MPLab but still nothing. If anyone can help us out, we would really appreciate it!
Unread 07-02-2007, 21:10
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Re: Potentiometer Problems
Well, firstly, are you sure you have the wires connected correctly. There should be a diagram of some sort on the pot itself, that looks like this.
(1)__________________(3)
(2)_________|
If the diagram isn't on there, the offset pin on the pot will be number 2. Pin 1 goes to white, 2 to red, and 3 to black, on a PWM cable from an Analog Input.
Other than that, I don't use easyc and I couldn't tell you if that's the problem.
void function(void)
  function();
Unread 07-02-2007, 23:33
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
(2)_________|
Don't you mean 1 to red, 2 to white, and 3 to black, or 1 to black, 2 to white, 3 to red? Or did I confuse something. I think if you do this, you will release some magic smoke. Please correct me if I'm wrong, I have our potentiometer connected this way and I'm about to connect it tomorrow. Please Please reply.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 07-02-2007, 23:46
Your description is confusing. Are you actually having problems with a potentiometer, or is your problem right now just with printing the value being read? It seems to me that your question actually belongs in the Programming forum where someone who knows EasyC might be able to help.
Unread 08-02-2007, 08:02
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
one thing that I can see that might be problem is you are locking yourself in an infinite while loop which might not be allow the program to print anything.
thats just what i see but, I have not worked with easy c.
Unread 08-02-2007, 09:39
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
With EasyC you don't need to worry about your loop speed like in MPLab, the while(1) loop is fine.
Isn't the potentiometer built in to EasyC, there should be a block under Inputs(I think) that says potentiometer that you can use that may help, although the way you are doing it should work fine.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 08-02-2007, 11:07
DonRotolo's Avatar
Back to humble
FRC #0832
You ae correct: One "end" of the pot goes to black, the other "end" goes to red - this puts a 5 volt potential across the entire pot. You then connect the Wiper of the pot to the white, so the RC can read the voltage at the wiper contact (which varies from 0 to 5 volts). Using the diagram, black goes to 1 or 3, red goes to 3 or 1, and WHITE goes to TWO.
Don
Unread 08-02-2007, 18:59
void* Jake;
FRC #1178 (DURT)
Why do I always screw things up when I'm trying to help someone? Yes, your wiring is right. 1 to red, 2 to white, 3 to black. There won't be any smoke if you do it incorrectly, though.
void function(void)
  function();
Potentiometer PID DustinB_3 Programming 28 15-02-2008 23:18
Potentiometer fezkazi Electrical 3 24-01-2007 13:29
Linear Potentiometer FRC1710 Motors 4 15-01-2007 19:20
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
