Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
  #106   Spotlight this post!
Unread 07-02-2007, 22:33
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
Re: does anyone have OI and RC radio issues
If you've done everything IFI suggested, called them, discussed your symptoms, and your radios are still having problems, they will give you a RMA number to have them repaired.
If you haven't tried their suggestions, or talked to them, and you're having problems...you should try their suggestions and/or talk to them. They're terribly helpful, and once it's clear there is no user error involved, will issue you the RMA.
  #107   Spotlight this post!
Unread 08-02-2007, 00:08
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Thumbs up Re: does anyone have OI and RC radio issues
Originally Posted by Jake M View Post
Based on what I've seen, I think that it is undoubtedly a hardware problem within the RC or the RC Radio itself (most likely the radio), for two reasons. First, I think we need to assume that the LEDs on the RC are working correctly, because if they're not then there's a hardware problem right there, in the RC. Second, if we assume that what the LEDs tell us is correct, then we know it's a hardware problem somewhere between the RC and the RC Radio, because when the signal loss occurs, the only LED that changes is the Radio State, which becomes red, indicating that there is no radio connected at all. From there, once you make sure that the cable connecting the two is in working condition its easy to understand how the problem has to be within the RC or the Radio Modem. And when you try using older modems and have no problems, you can eliminate the RC.
Anyway, to me the only logical conclusion is that the problem is within the radio itself, especially considering that the teams that have received new radios have had no problems at all.
And my last question was, do the teams who received new radios still notice that it takes several seconds for the radios to initially synchronize?
Based on our tests, yes, but it doesn't really matter since its not really THAT long. Once they connect, they are good to go!
  #108   Spotlight this post!
Unread 08-02-2007, 00:53
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Originally Posted by roboticsguy1988 View Post
Our team started experiencing problems again. We changed the configuration, per the third post located at IFI's Forums.
We found that when you make both perpendicular to the floor and away from metal objects they work perfect. But you get a metal object near one of them, or in there line of site they have problems at times. After talking to IFI, they had told us two things to read that post and follow what it said there, and to keep it away form metal objects. Now this seems weird considering most of the field is metal, and the rack in the center is all metal, and other robots are made out of metal....
Obviously you wouldn't want to put your RC radio in the bottom of the robot next to the motors, and you could have some problems, BUT with good visible mounting away electronics and metal, and they still don’t work right, it is a serious problem. This is FIRST and there will be a myriad of metalic objects moving on the field at a time, so chances are, "no metal objects" in its line of sight is obviously not a viable possibility. I have Faith that IFI will have this solved in a week. Go FIRST
Hows my searching? Call 1-800-Green-Dots
  #109   Spotlight this post!
Unread 09-02-2007, 08:07
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
We got our radios kind of working by getting them at least 8" away from any metal objects. I did tests by blocking the OI radio with an aluminum plate and also positioning the RC radio around in the chassis (w/ and without metal nearby). It looks like if these radios are within 6-8" of aluminum they lose comm (orientation didn't seem to matter). Thats a big problem... We're looking at making a special plastic mount to get this thing up and away from everything else just to ensure a constant signal. The old radios work great no matter where you place them. However they have plastic antennas and these new ones have metal antennas. I wonder if that has anything to do with it. I think FIRST needs to let us use the previous years radios. Theres no way 2000 teams are going to be able to keep their radios in comm and away from aluminum obstructions.
ETA from the IFI Forum (and this IS the fix):
"Poor reception can also be caused from incorrect mounting and wiring. For best radio reception, follows the guidelines: 1) the RC and OI Radio Modems should be mounted high and perpendicular to the playing field. 2) Both the Radio Modem Case and the moveable Antenna should be perpendicular to the playing field. 3) The Radio Modems and DB9 Radio Modem Cables should be kept as far as possible from any High Current Wiring, Motors, and Victors ….etc. 4) The Radio Antennas should not be touching any other surface. 5) The Radio Modem Case and Antennas should not be shielded by any metal structure. 6) There should be a “Clear Line-of Sight” between the RC and OI Radio Modems case and Antenna. 7) Interference from another radio source can be solved by changing to a different practice channel."
But these requirements can be a real pain in the neck depending on your design...
www.179swampthing.org
  #110   Spotlight this post!
Unread 09-02-2007, 08:21
This brings up some interesting issues with the radios this year. So that everyone knows, the FCC site has internal photos of the radios. These photos show a second antenna withing the black enclosure. It is positioned on the side oppositie the metal antenna. I expect that teams will find more stable communications if this side of the enclosure is positioned away from metal support structure. Only time will tell.
  #111   Spotlight this post!
Unread 09-02-2007, 12:38
Samara's Avatar
Samara Samara is offline
AKA: *~*Jackie*~*
FRC #1511 (Rolling Thunder)
Samara will become famous soon enoughSamara will become famous soon enough
Send a message via AIM to Samara Send a message via MSN to Samara Send a message via Yahoo to Samara
Originally Posted by esquared View Post
We tested extensively on Saturday and Sunday, both in autonomous and manual drive modes, and continued to experience radio cutouts. After nearly squashing a mentors foot with a speedy autonomous (and un-killable) robot, we reverted to last years radios. I obtained a RMA from IFI on Tuesday afternoon, and our modems ship out Thursday morning.
--Eric
It attacked me too eric =(
Tell me and I forget; show me and I remember; involve me and I understand.
-Anonymous
  #112   Spotlight this post!
Unread 09-02-2007, 15:41
While this helps, this in no way solves the problem Now it only cuts out every 10 seconds instead of every 5. 2006 Radios ftw
  #113   Spotlight this post!
Unread 09-02-2007, 15:50
esquared's Avatar
AKA: Angry Eric
Team Role: Mascot
Call IFI, get an RMA, get them fixed, get them back. This is your last week to do it, and shipping only gets more expensive the longer you wait. They've only had 10 radios to date returned to them, so as it stands right now there is no mass reason not to use the 2007 radios.
Still, I wouldn't want to be at the first regional this year when there are 30 or 40 of these things on at once.
Our team will be getting our radios back from IFI bright and early tomorrow morning, and I'll report whether or not ours work like waialua's do now.
  #114   Spotlight this post!
Unread 09-02-2007, 17:11
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
They will have 11 when my teams' get there I just sent in my teams yesterday they should be getting them monday! IFI told me to move the modem away from any motors or anything metallic so this is what I did I used a brand new DB9 Cord and put the radio next to the OIs Radio, Put the robot up on wooden chocks and guess what I still had problems and this time the robot wasn't even moving it the signal would just come and go randomly and I said before in prior posts I had this robot in a room where no interference can exsist. It seems like theres more to this story then they care to admit. When you have both the OI & the RC Radios within a foot of one another and neither one of them is near the robot and you still have issues I'd say that thats a defect right there. The 2007 setup worked flawlessly when I had the 2006 Radios hooked up
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
  #115   Spotlight this post!
Unread 09-02-2007, 17:20
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Is this a problem that exists with all Radios, or just some? We drove our robot yesterday for about 4 hours straight with no problems with losing communication.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
  #116   Spotlight this post!
Unread 10-02-2007, 09:38
Mike,
Putting radios close together can be just as much a problem as mounting next to metal or being far away. The high RF levels may just overload the receivers at that close a distance causing distortion in the receiver front end (preamp).
  #117   Spotlight this post!
Unread 11-02-2007, 11:07
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
We are having drop out problems with our radio communications too and I thought we had these solved but they came back again....
When we initially had problems with this, our antenna on the robot was within 1 foot away from the drive motors. I then moved it and mounted it on a metal mast which is part of our arm lift mechanism and it was working just fine but now it sems to drop out every 15 seconds or so while driving the robot.
We notice the OI PWM red lights (for the drive motors) are on constant when this happens and sometimes the red No Data/Radio or the No Data lights on the OI light up and stay on for 20 seconds or more while the robot is dead in its tracks. I notice dthat reset clears this and will re-enable the robot.
The green lights on the robot antenna are usually blinking on an off and I have noticed that they do not blink as fast when this condition occurs.
Is this a problem with the RC, the OI, or the antennas?
I am beginning to wonder if this is a susceptibility problem with the antenna unit where we are picking up interference from something else... The location where we are testing the robot has a wireless network, could this be causing some of the problems?
We are also having run-on problems and will load the v14 bin file later today but from what I have read this will probably not fix the drop out problem.
We just wasted a day finding a bind up problem on one of the cim motors and now this is keeping us from the precious time we need...
Any suggestion of how we can over come this problem are greatly appreciated.
Thank you in advance for your advice on the drop out problem.
  #118   Spotlight this post!
Unread 11-02-2007, 12:27
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
hmm no no problems but our antenna did break off...
"we don't build robots, we build people"
  #119   Spotlight this post!
Unread 11-02-2007, 18:16
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
1625 is having radio issues as well. In competition mode, the problem gets even worse.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
  #120   Spotlight this post!
Unread 13-02-2007, 03:36
waialua359's Avatar
AKA: Glenn
I am very concerned that as it gets close to the end of build season, many teams will be faced with this problem and the ramifications may be enormous such as not being able to test, waiting for new radios, etc.
Does Anyone Have a Liability Form? Beth Sweet General Forum 5 21-12-2004 22:58
Does anyone Have? Chris Championship Event 0 24-04-2003 18:46
Does Anyone have advice archiver 2001 2 23-06-2002 23:50
Does anyone have... archiver 1999 2 23-06-2002 22:59
Does anyone have a picture of the Pratt and Whitney engine that was at Nats.? Elgin Clock Championship Event 4 08-05-2002 21:31
