Re: Question on mounting PVC for flag
that swings around. It would be reasonable to mount it so that it sticks up 18 inches higher than the highest portion of your robot that does not swing around, so that it is easily seen. Eugene |
<R15> says, in part:
If you were to mount it in such a way that the arm cannot waste it and it is the highest point without damaging the flag, im sure it will work.
Chris |
what about if the highest point of a teams robot is their ramps, and they come down at the end of the match, are you allowed to attached the flag holder to the top of the ramp so it will com down with the ramp? or does it have to hold its own at that height?
http://forums.usfirst.org/showthread.php?t=3445
Q:We have a question concerning the placement of the flag. One of our ideas is to have a large unfolding ramp, onto which we would mount the flag. Throughout the majority of the match, our ramp will be folded up, and is by far the highest point on the robot. When our ramp unfolds in the last 15 seconds of the match, the flag would be lower than the rest of our robot, and would be pointed horizontally. Since this is a temporary condition, only at the end of the match, would this be permissible? A:No. That would be a violation of Rule <R15>. |
See this one too: http://forums.usfirst.org/showthread...highlight=flag
it looks like if we can come up with a way to keep our flag verticalat all times even if it comes down with the ramp. like have the flag holder on a hinge and the bottom weighed down to keep it straight up. that would make it higher that the tallest point of our robot, assuming we are completly flat when the ramps are down. do you think that would be a violation or not?
#8
This is still not clear. Even though it says to be 18" higher than the central mass of the robot, it is still subjective due to ramps deploying, moving arms, etc.
Every team technically will have a different design which may dictate the correct height/positioning of the flag. |
#9
This seems pretty clear to me. The flag should be above most of the robot most of the time. The holder needs to stay vertical so you don't dump it out on the field.
Remember, this is for identification purposes so think about that when placing your tube. Wetzel |
#10
However, "The flag should be above most of the robot most of the time" is still vague. |
#11
We will be mounting it where "we feel is right". If it's not right at the competition, then we'll just simply ask the inspector to suggest a better place. This is why we never somewhat permanently mount the PVC.
#12
The problem for us is that our entire robot minus arm and ramp is only 12.25" above the ground max. If our ramp is deployed and arm moves which is just under 4' in the starting position, it will certainly rotate and move during the match, thus not give our flag a permanent vertical positioning.
Cant see making a 3' extension just for a flag. We want to put our flag 18" above the central mass of the robot which is right above 12.25," but they may say "NO," it has to be 18 " higher than our 4' starting point, thus forcing us to create a huge "flagpole." |
| Question on mounting components | BQuennell | Electrical | 7 | 31-01-2007 12:01 |
| Trouble finding flat pvc sch 40 PVC caps | Gdeaver | Kit & Additional Hardware | 8 | 12-01-2005 14:21 |
| [OCCRA]: Rules Question: Can the flag move the arrow? | wbhsAndy | OCCRA Q&A | 1 | 27-10-2004 11:01 |
| Wave a Flag for our troops! | Alex Cormier | Chit-Chat | 3 | 25-03-2003 17:57 |
| PVC Question | archiver | 2000 | 1 | 24-06-2002 00:09 |
