Re: Team 172 - Electrical Done!
According to the wiring diagram they sent us the returns on the 40 Amp circuits are to go to the distribution block not the ground on the other fuse panel. I guess it won't make much of a difference, but some inspectors may get a bit picky on this. Correct me if I'm wrong?
wow.. season after season I see the electrical board getting cleaner and nicer
The revised electrical diagram and the Tips and Guidelines show the high current (40amp) returns going back to the Rockwell block. This is actually a much better way to handle the high current returns as it provides the lowest series resistance path to the battery. I expect that inspectors will be looking for compliance with the documents. Sorry. The rest of the layout looks very nice, you get a gold star. |
Nice, it does look a bit jumbled though. My only concern is if you were to have a problem, you could lose valuable minutes figuring out what wires are what.
Chris |
#7
Hey guys that looks pretty good for the space that you guys had to work with. You guys did a great job!
#8
Thanks for all the input guys!
...As for the 40 amp grounds, thanks for pointing that out. I couldn't find a written rule requiring the return to the DIN blocks so I've held off in changing it. I'll fix it tonight though if you all think it will be a problem. (good to do the little work now rather than before a match in Manchester.) As for being jumbled, it admittedly is. Last night I installed shrink tubing labels to all of the crimp connectors on the fuse block end, and all of the control cables have been labeled from the start. This in addition to component-side labels and good bookkeeping is all I can really do. I only have so much space to work with and a good number of wires to fit in, so some sacrifices have to be made. So it goes. ![]() |
#9
Remember, you can combine multiple #10 and smaller gauge wires into a single "port" in the distribution block, allowing you to terminate 4 SIM motor grounds with a minimum of two black blocks.
Also, I've noticed your 40A circuit supply wire is not directly across the block that houses your positive supply from the 120A breaker. You may want to consider swapping the two wires that lead to your 40A Maxi and the other breaker panel to keep your highest current draws from crossing the "yellow brick jumper" as I call it. My $.02. Cheers. |
#10
Thanks! |
#11
-Danny |
#12
K.,
<R85> Electrical devices must be wired in accordance with Section 8.3 Robot Rules, using commercially available copper wire for all electrical connections. Aluminum (or other noncopper material) wire is prohibited. For examples of acceptable circuit designs, please see the 2007 Robot Power Distribution Diagram. Please see the revised diagram on the First website. I am recommending that teams using the jumper, feed the power inputs to the center of the block so that the current divides down both sides of the jumper. This way the current is divided somewhat so that it does not all pass through the entire jumper. |
#13
I've just finished re-wiring the 40 amp Victors as per the diagram. All four of them are now routed to the terminal block (and subsequently, the wiring looks a wee bit neater too!)
Thanks for all the input, this would have been bad to miss before the competition! |
| Team 172 Prototyping | K.Porter | Robot Showcase | 9 | 16-01-2007 00:28 |
| pic: Team 213 done | Daniel Morse | Robot Showcase | 2 | 22-02-2006 22:41 |
| pic: Team 56 Almost Done | jfischer | Robot Showcase | 12 | 18-02-2005 23:41 |
| Team 11 is done! | oneeightytwo | Robot Showcase | 3 | 09-02-2003 19:27 |
| Team 122 is done! | Johca_Gaorl | General Forum | 39 | 06-01-2003 20:44 |
