Go to Post Winning or losing on the field has nothing to do with this success. - E. Wood [more]
Unread 07-02-2007, 21:31
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Team 172 - Electrical Done!
After, well, too long waiting for cables, I can now effectively say that the electrical board is done!
...I now just need the mechanical guys to tell me where I can put it.
Here's everything electrical fit on one little board for this year. I swear that it looked much neater before all the PWM cables went in!
Questions? Comments? Concerns? Thanks!
Unread 07-02-2007, 22:13
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Re: Team 172 - Electrical Done!
That looks really good, nice and compact.
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 07-02-2007, 23:04
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
Thumbs up Re: Team 172 - Electrical Done!
hahaha cool, but the wires make it look kind of messy, it would suck if you have a wiring problem and cant figureout wheres what. but its nice though!
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
Unread 07-02-2007, 23:21
Weepy's Avatar
Weepy Weepy is offline
Space Dog
AKA: Adrian Choy
FRC #2047 (Team Challenger)
Team Role: Marketing
Weepy is just really niceWeepy is just really niceWeepy is just really niceWeepy is just really nice
Send a message via AIM to Weepy
ALOT more organized than our team's setup.
I guess you can't fix every problem by throwing twist ties at it
Adrian
-Head of Marketing
-Electrical Team
-Robot Fabrication Team
Freelance artist, college bound engineer, loving father.
Do you fear my karate?
2007 Wisconsin Regional XEROX Creativity Award and
2007 Midwest Regional Rookie All-Star Award recipients!
Unread 08-02-2007, 00:51
CrosbyAR's Avatar
CrosbyAR CrosbyAR is offline
AKA: Alex Crosby
FRC #0229 (Division By Zero)
CrosbyAR is a jewel in the roughCrosbyAR is a jewel in the roughCrosbyAR is a jewel in the rough
Send a message via AIM to CrosbyAR
A bit cramped ? Is that all the room you had?
Alexander Crosby
FRC Team 229 Team Leader
The Wallace H. Coulter School of Engineering
Mechanical and Aeronautical Engineering Dept.
Clarkson University 2008
Unread 08-02-2007, 01:12
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Wait... I didn't have to use the whole power block.... Bah.
I told them I didn't have to, but they said I did. Oh well.
Very nice, ours are pretty close to the same... cables cut exactly to length, although it's spaced out a little more. Dang those PWM's though huh... I considered cutting to length but then the reuse is lost. =(
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 08-02-2007, 02:03
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
According to the wiring diagram they sent us the returns on the 40 Amp circuits are to go to the distribution block not the ground on the other fuse panel. I guess it won't make much of a difference, but some inspectors may get a bit picky on this. Correct me if I'm wrong?
Unread 08-02-2007, 02:21
Joel J's Avatar
Joel J Joel J is offline
do you..
I was thinking the same thing, but couldn't find the specific rule in the manual. I'm using the PDB, just in case.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 08-02-2007, 02:34
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
wow.. season after season I see the electrical board getting cleaner and nicer
| jamesyong.net |
FVC2007, FTC2008
Unread 08-02-2007, 03:08
I hope thats not true. That would be a total waste, requiring teams with 4 CIM motors to use at least 3 of the ground blocks instead of just grounding on the smaller breaker panel. Maybe there's worries about the amperage of 4 Cims, 1 Mini Bike, and 2 FP going through that little metal plate?
Unread 08-02-2007, 08:03
Doug and K.,
The revised electrical diagram and the Tips and Guidelines show the high current (40amp) returns going back to the Rockwell block. This is actually a much better way to handle the high current returns as it provides the lowest series resistance path to the battery. I expect that inspectors will be looking for compliance with the documents. Sorry.
The rest of the layout looks very nice, you get a gold star.
Unread 08-02-2007, 08:44
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Nice, it does look a bit jumbled though. My only concern is if you were to have a problem, you could lose valuable minutes figuring out what wires are what.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 08-02-2007, 10:51
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Hey guys that looks pretty good for the space that you guys had to work with. You guys did a great job!
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 08-02-2007, 15:04
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
Thanks for all the input guys!
...As for the 40 amp grounds, thanks for pointing that out. I couldn't find a written rule requiring the return to the DIN blocks so I've held off in changing it. I'll fix it tonight though if you all think it will be a problem. (good to do the little work now rather than before a match in Manchester.)
As for being jumbled, it admittedly is.
Last night I installed shrink tubing labels to all of the crimp connectors on the fuse block end, and all of the control cables have been labeled from the start. This in addition to component-side labels and good bookkeeping is all I can really do. I only have so much space to work with and a good number of wires to fit in, so some sacrifices have to be made. So it goes.
Unread 08-02-2007, 16:43
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
Remember, you can combine multiple #10 and smaller gauge wires into a single "port" in the distribution block, allowing you to terminate 4 SIM motor grounds with a minimum of two black blocks.
Also, I've noticed your 40A circuit supply wire is not directly across the block that houses your positive supply from the 120A breaker. You may want to consider swapping the two wires that lead to your 40A Maxi and the other breaker panel to keep your highest current draws from crossing the "yellow brick jumper" as I call it.
My $.02.
Cheers.
Team 172 Prototyping K.Porter Robot Showcase 9 16-01-2007 00:28
pic: Team 213 done Daniel Morse Robot Showcase 2 22-02-2006 22:41
pic: Team 56 Almost Done jfischer Robot Showcase 12 18-02-2005 23:41
Team 11 is done! oneeightytwo Robot Showcase 3 09-02-2003 19:27
Team 122 is done! Johca_Gaorl General Forum 39 06-01-2003 20:44
